SnowDrift
Ultra Conservative. ULTRA!
1994 K1500 Suburban
We just replaced the battery and alternator because the voltage kept dropping off when the electrical system was under a load, especially with the a/c on. It was to the point that the a/c on and blowers on high upon startup one day, the engine died twice right when I started it up.
What else can I check that could be causing the voltage to read low and not seem to recover a full charge? The turn signal causes the needle on the gauge to flicker much more than I think is normal, also.
