Jaryd
Extremely Deplorable
For the past year or so when I go to cut the air condition or heat on it takes a minute for the air to come out of whatever vents the knob is on. The fan speed has always worked as it should but sometimes when I cut the fan on I can here the fan in the dash running but the airs not coming out of the vents anywhere. I have to cycle the vent selection knob or the fan speed knob on and off a few times and then it’ll work.
Question is what should I look at? The switches on the dash or the stuff on the fan (pigtails, diodes.....I don’t know what all makes it work)? I looked through some of the threads that has popped up recently about this but still have no idea where to start.
Next thing is I have had LOW heat ever since my last heater core went out about 2 years ago. When the heater core started leaking I had normal heat. Once I changed it out I never could get real heat again. I flushed the BrassWorks heater core to make sure it wasn’t plugged. It was fine. I changed to a 195* TSAT and flushed the engine. Before I put the BrassWorks core in again I watched what blend doors I could see (looking up into the dash from where the core goes) move when I turned the knob on the dash.
Next question is where do I go from here?
I think I have two problems going on. The low heat problem and the blend doors not working as they should.
