ripmf666
Registered user
<FORM onsubmit="JavaScript: return true;" method=post name=CellHandlerForm action=/si/cellHandler.do> Document ID: 666773 <HR>
Fan Pulley Removal
<LI type=1>Disconnect the camshaft position sensor connector. <LI type=1>Remove the cooling fan pulley bolts and nuts. <LI type=1>Remove the cooling fan pulley and insulator pad.
<LI type=1>Remove the camshaft position sensor retaining bolt.- Remove the camshaft position sensor.
</FORM>
