ripmf666
Registered user
<FORM onsubmit="JavaScript: return true;" method=post name=CellHandlerForm action=/si/cellHandler.do> Document ID: 727531 <HR>
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=727531&from=sm#oth1-727531">Engine Cover Components
<MAP name=692526.map><TABLE><TBODY><TR><TH align=left></TH></TR><TR><TD align=middle>(1)</TD><TD align=left>Coolant Temperature Sensor</TD></TR><TR><TD align=middle>(2)</TD><TD align=left>Thermostat (Front)</TD></TR><TR><TD align=middle>(3)</TD><TD align=left>Thermostat (Rear)</TD></TR><TR><TD align=middle>(4)</TD><TD align=left>Heater Pipe Bolt</TD></TR><TR><TD align=middle>(5)</TD><TD align=left>Heater Pipe</TD></TR><TR><TD align=middle>(6)</TD><TD align=left>Thermostat Cover</TD></TR><TR><TD align=middle>(7)</TD><TD align=left>Thermostat Cover Bolt</TD></TR><TR><TD align=middle>(8)</TD><TD align=left>Water Outlet O-ring</TD></TR><TR><TD align=middle>(9)</TD><TD align=left>Water Outlet Bolt</TD></TR><TR><TD align=middle>(10)</TD><TD align=left>Water Outlet</TD></TR><TR><TD align=middle>(11)</TD><TD align=left>Water Outlet Bolt</TD></TR><TR><TD align=middle>(12)</TD><TD align=left>Oil Fill Cap</TD></TR><TR><TD align=middle>(13)</TD><TD align=left>Oil Fill Tube Bolt</TD></TR><TR><TD align=middle>(14)</TD><TD align=left>Oil Fill Tube</TD></TR><TR><TD align=middle>(15)</TD><TD align=left>Oil Fill Tube O-ring</TD></TR><TR><TD align=middle>(16)</TD><TD align=left>Engine Front Cover</TD></TR><TR><TD align=middle>(17)</TD><TD align=left>Fuel Injection Pump Bolt</TD></TR><TR><TD align=middle>(18)</TD><TD align=left>Engine Assembly</TD></TR><TR><TD align=middle>(19)</TD><TD align=left>Fuel Injection Pump</TD></TR><TR><TD align=middle>(20)</TD><TD align=left>Flywheel Housing Cover Bolt</TD></TR><TR><TD align=middle>(21)</TD><TD align=left>Flywheel Housing Cover</TD></TR><TR><TD align=middle>(22)</TD><TD align=left>Flywheel Housing Cover Gasket</TD></TR><TR><TD align=middle>(23)</TD><TD align=left>Flywheel Housing O-ring</TD></TR><TR><TD align=middle>(24)</TD><TD align=left>Flywheel Housing</TD></TR><TR><TD align=middle>(25)</TD><TD align=left>Flywheel Housing Bolt</TD></TR><TR><TD align=middle>(26)</TD><TD align=left>Dowel Pin</TD></TR><TR><TD align=middle>(27)</TD><TD align=left>Crankshaft Rear Oil Seal</TD></TR><TR><TD align=middle>(28)</TD><TD align=left>Engine Oil Cooler Adapter Gasket</TD></TR><TR><TD align=middle>(29)</TD><TD align=left>Engine Oil Cooler Adapter Bolt</TD></TR><TR><TD align=middle>(30)</TD><TD align=left>Engine Oil Cooler Adapter Bolt</TD></TR><TR><TD align=middle>(31)</TD><TD align=left>Engine Oil Cooler Adapter</TD></TR><TR><TD align=middle>(32)</TD><TD align=left>Engine Oil Cooler Adapter Gasket</TD></TR><TR><TD align=middle>(33)</TD><TD align=left>Oil Pump Pipe and Screen Assembly Bolt</TD></TR><TR><TD align=middle>(34)</TD><TD align=left>Oil Pump Pipe and Screen Assembly</TD></TR><TR><TD align=middle>(35)</TD><TD align=left>Oil Pump Pipe and Screen Assembly Gasket</TD></TR><TR><TD align=middle>(36)</TD><TD align=left>Oil Level Tube Bolt</TD></TR><TR><TD align=middle>(37)</TD><TD align=left>Oil Level Tube</TD></TR><TR><TD align=middle>(38)</TD><TD align=left>Oil Level Tube O-ring</TD></TR><TR><TD align=middle>(39)</TD><TD align=left>Oil Level Sensor Bolt</TD></TR><TR><TD align=middle>(40)</TD><TD align=left>Lower Oil Pan Stud</TD></TR><TR><TD align=middle>(41)</TD><TD align=left>Oil Level Sensor</TD></TR><TR><TD align=middle>(42)</TD><TD align=left>Retainer</TD></TR><TR><TD align=middle>(43)</TD><TD align=left>Lower Oil Pan Bolt</TD></TR><TR><TD align=middle>(44)</TD><TD align=left>Oil Drain Plug</TD></TR><TR><TD align=middle>(45)</TD><TD align=left>Oil Drain Plug Gasket</TD></TR><TR><TD align=middle>(46)</TD><TD align=left>Lower Oil Pan</TD></TR><TR><TD align=middle>(47)</TD><TD align=left>Upper Oil Pan Bolt</TD></TR><TR><TD align=middle>(48)</TD><TD align=left>Upper Oil Pan</TD></TR><TR><TD align=middle>(49)</TD><TD align=left>Oil Pump</TD></TR><TR><TD align=middle>(50)</TD><TD align=left>Oil Pump Bolt</TD></TR><TR><TD align=middle>(51)</TD><TD align=left>Oil Pump Driven Gear</TD></TR><TR><TD align=middle>(52)</TD><TD align=left>Oil Pump Driven Gear Nut</TD></TR><TR><TD align=middle>(53)</TD><TD align=left>Engine Front Cover</TD></TR><TR><TD align=middle>(54)</TD><TD align=left>Engine Front Cover Bolt</TD></TR><TR><TD align=middle>(55)</TD><TD align=left>Oil Pressure Relief Valve</TD></TR><TR><TD align=middle>(56)</TD><TD align=left>Thermostat Bypass Pipe Gasket</TD></TR><TR><TD align=middle>(57)</TD><TD align=left>Thermostat Bypass Pipe Bolt</TD></TR><TR><TD align=middle>(58)</TD><TD align=left>Thermostat Bypass Pipe</TD></TR><TR><TD align=middle>(59)</TD><TD align=left>Thermostat Bypass Pipe O-ring</TD></TR><TR><TD align=middle>(60)</TD><TD align=left>Thermostat Housing Bolt</TD></TR><TR><TD align=middle>(61)</TD><TD align=left>Thermostat Housing Nut</TD></TR><TR><TD align=middle>(62)</TD><TD align=left>Thermostat Housing Bolt</TD></TR><TR><TD align=middle>(63)</TD><TD align=left>Thermostat Housing Nut</TD></TR><TR><TD align=middle>(64)</TD><TD align=left>Thermostat Housing</TD></TR><TR><TD align=middle>(65)</TD><TD align=left>Thermostat Housing Gasket</TD></TR><TR><TD align=middle>(66)</TD><TD align=left>Thermostat Housing Stud</TD></TR><TR><TD align=middle>(67)</TD><TD align=left>Camshaft Position Sensor O-ring</TD></TR><TR><TD align=middle>(68)</TD><TD align=left>Camshaft Position Sensor</TD></TR><TR><TD align=middle>(69)</TD><TD align=left>Camshaft Position Sensor Bolt</TD></TR><TR><TD align=middle>(70)</TD><TD align=left>Crankshaft Position Sensor Bolt</TD></TR><TR><TD align=middle>(71)</TD><TD align=left>Crankshaft Position Sensor</TD></TR><TR><TD align=middle>(72)</TD><TD align=left>Crankshaft Position Sensor O-ring</TD></TR></TBODY></TABLE>
© 2010 General Motors. All rights reserved.
</FORM></MAP>
