ripmf666
Registered user
<FORM onsubmit="JavaScript: return true;" method=post name=CellHandlerForm action=/si/cellHandler.do>Document ID: 727535 <HR>
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=727535&from=sm#oth1-727535">Cylinder Head Components
<MAP name=692530.map><TABLE><TBODY><TR><TH align=left></TH></TR><TR><TD align=middle>(1)</TD><TD align=left>Cylinder Head</TD></TR><TR><TD align=middle>(2)</TD><TD align=left>Rocker Arm Shaft Plug</TD></TR><TR><TD align=middle>(3)</TD><TD align=left>Rocker Arm Shaft Mount</TD></TR><TR><TD align=middle>(4)</TD><TD align=left>Rocker Arm Shaft Mount Bolt</TD></TR><TR><TD align=middle>(5)</TD><TD align=left>Rocker Arm Shaft Assembly Lock Nut</TD></TR><TR><TD align=middle>(6)</TD><TD align=left>Rocker Arm Shaft Assembly</TD></TR><TR><TD align=middle>(7)</TD><TD align=left>Fuel Injector Harness</TD></TR><TR><TD align=middle>(8)</TD><TD align=left>Fuel Injector Harness Bolt</TD></TR><TR><TD align=middle>(9)</TD><TD align=left>Valve Bridge Pin</TD></TR><TR><TD align=middle>(10)</TD><TD align=left>Valve Bridge</TD></TR><TR><TD align=middle>(11)</TD><TD align=left>Valve Key</TD></TR><TR><TD align=middle>(12)</TD><TD align=left>Valve Spring Seat (Upper)</TD></TR><TR><TD align=middle>(13)</TD><TD align=left>Valve Spring</TD></TR><TR><TD align=middle>(14)</TD><TD align=left>Valve Spring Seat (Lower)</TD></TR><TR><TD align=middle>(15)</TD><TD align=left>Fuel Injector Gasket</TD></TR><TR><TD align=middle>(16)</TD><TD align=left>Fuel Injector Seal (O-ring)</TD></TR><TR><TD align=middle>(17)</TD><TD align=left>Fuel Injector</TD></TR><TR><TD align=middle>(18)</TD><TD align=left>Fuel Injector Bracket Bolt</TD></TR><TR><TD align=middle>(19)</TD><TD align=left>Fuel Injector Bracket</TD></TR><TR><TD align=middle>(20)</TD><TD align=left>Fuel Return Pipe</TD></TR><TR><TD align=middle>(21)</TD><TD align=left>Fuel Return Pipe Bolt</TD></TR><TR><TD align=middle>(22)</TD><TD align=left>Fuel Return Pipe Gasket</TD></TR><TR><TD align=middle>(23)</TD><TD align=left>Glow Plug</TD></TR><TR><TD align=middle>(24)</TD><TD align=left>Glow Plug Connector-Model Dependent (Federal Emissions)</TD></TR><TR><TD align=middle>(25)</TD><TD align=left>Glow Plug Connector-Model Dependent (CA Emissions)</TD></TR><TR><TD align=middle>(26)</TD><TD align=left>Cylinder Head</TD></TR><TR><TD align=middle>(27)</TD><TD align=left>Exhaust Valve</TD></TR><TR><TD align=middle>(28)</TD><TD align=left>Pushrod</TD></TR><TR><TD align=middle>(29)</TD><TD align=left>Valve Clearance Adjusting Screw</TD></TR></TBODY></TABLE>
© 2010 General Motors. All rights reserved.
</FORM></MAP>
