I keep getting pump and other codes and need some help figuring this out. The truck is a 95 K1500. Started out earlier this year with first a no start and then hard start with pump codes, ran the atf through the pump a few times and it cleared and worked fine for a short time and then it started to act up again and I was getting bucket loads of codes, the IP codes where the same but the rest was different each time. unplugged the rear harness and it cleared out, found there was water in the extra led backup lights I had installed. After I removed these it ran fine for a few days until I parked it and went away for work.
Came home last week and hooked up the caravan for a trip stopped at the mall for some supplies and didnt get any further,a short in the starter motor. Borrowed another truck and got the trip done. Have now changed the starter and it ran fine.
Today I was going to haul a load of firewood and after about 30 minutes it stumbles and the check engine light comes on, stops and restarts and everything is fine, this repeats a couple of more times and then it doesnt help to restart. According to ALDLDROID the timing on the pump is stuck at 25.5.
Checked the codes and got this list.
16 - Vehicle speed sensor buffer fault
17 - High resolution circuit fault
18 - Pump cam reference pulse error
35 - Injection pulse width error (response time long)
36 - Injection pulse width error (response time short)
49 - Service throttle soon lamp circuit fault
54 - PCM fuel circuit error
84 - Accelerator pedal position circuit fault
99 - Accelerator pedal position 2 (5volt reference fault)
Cleared the codes and went another 5 miles to my destination, checked the codes again and had:
Cleared the codes again and restarted while parked and checked codes and 18 and 35 come on right away, checked with GMTDScan while trying to start, it has a long crank and doesnt start until the software has detected 8 missed cam references.
Another thing I have noticed is when I have this problem I get zapped with static every time I exit the truck.
Things that I have done, have checked grounds and added extras for good measure. Rewired the pump harness, the pmd is located in the front bumper. Had the complete engine wire harness out and checked all wires and contacts and measured the resistance in every cable. Checked with clear hose for air in fuel, checked lift pump and it delivers plenty fuel.
Any ideas where I go next?
