WayneB
I'm Crying Uncle... It's time to ask the brain trust!
I have a 1995 6.5 with a cold start smoking & stumbling issue I can't figure out?
Here is what has been done.
Checking for air in the fuel:
* I have went through the fuel system front to back, supply and return. Using the clear hose to look for air. I did find a couple air leaks and fixed them.
* I have noticed a couple bee bee sized air bubble in the line after letting it set over night (cold is 40deg. or so) I also have about 1 second's worth of small bubbles quickly passing then it starts, it quickly clears and runs. Where is that second's worth of bubbles/foam coming from on start up? It comes and passes pretty quick so it's not far down the fuel system?
Checking the IP timing:
I adjusted the IP average to 3.0 ~ 4.0 = 3.5 avg. and the TDOC to .88 It sure don't take much to move things. I was working to the right or left of the witness mark chiseled into the metal.
Here is an odd observation. When I plug in the block heater overnight there are no start up problems. The truck starts right up with next to no smoke or coughing... with that small amount bubbles passing.
What's left?
It must be something metal that closes up when warm?
If it was an injector leaking fuel it would do it warm or cold. Yes?
I'm not loosing any coolant, and again it would do it warm or cold.
Would a loose IP line not under pressure leak air and not fuel? I don't see any fuel leaking in the valley.
Truck starts and runs fine when warm.
I'm at a loss....? Anyone have any suggestions?
Other work done:
New glow plugs, harness and controller from Quadstar.
New Bosch injectors from Accurate diesel.
New main wiring harness Quadstar.
New fuel manager from Quadstar...
New rebuilt IP from Quadstar. Installed and set it up by John himself. Yup, John lives about 12 miles from me. The white smoke started as things got progressively colder around here. The colder it gets the worse the smoke and stumbling gets.
What's left?
Other work done:
