ok i have been toying around with this 6.5TD i just got. GM8 turbo, marine injectors, 98 lower end, SSD ecm, 80 hp chip ,the pmd has been moved ,3-4 down pipe with 4inch exhaust ,egt, trans ,and boost gauges. i dont agree with alot of the parts that were put on this truck but i bought it this way! ok on start up i have alot of white/gray smoke, no coolant burning. mainly on a cold idle it has a knock and sometimes when warm idling it has the same knock. i rueld out the harmonic balancer and TC bolts. i think its in the fuel system. i need help and ideas please! also the truck has arp head bolts and new gaskets and runs great aside from the knock.
