Help in identifying this manual transmission?
Road_Case
South Florida
Went and took a look at a manual transmission today. Supposedly a 5-speed out of a 1990.
Should I rush back there and pick this up because I had no idea what I was looking at?
I will attach a photo of the ID tag from the side of the case. I can't find any info on whether or not this came in Chevys or GMCs. Also apparently this truck was a 2wd. Can this be adapted to work with my current TH400/NP241c setup?
Thanks in advance.
Looks like the 90 was a Topkick C6500... definitely a large transmission not meant for 2wd pickup use, let alone a 4wd pickup.... :) Not saying you cant make it work, but a NV4500 would go in alot easier.
Thanks guys. I won't be heading back in that case. I thought perhaps he had an SM465 which I probably would have bought off him even though it's 4th and final gear is still 1:1.
