I have a 1993 Safari Motorhome with a 6.5 turbo diesel. It is a rear engine pusher. I need help figuring out a glow plug controller issue. The controller is brand new. I have 12 volts to the battery side of the controller but no voltage to the glow plug side. There are 4 wires on top. With the key on the pink wire is hot but still no power to glow plugs. Any help would be appreciate. The oil pressure switch and the lift pump are new so not part of the problem. I have a new ignition switch but if pink wire is activated with key on it appears to be good. Would any of the other 4 wires be activated with the ignition?
