SnowDrift
Ultra Conservative. ULTRA!
Is it the 800141 for DS4 fueled engines?
Second, does the same damper work if I eventually switch to DB2?
Yes.Is it the 800141 for DS4 fueled engines?
Came across my spacer a while ago and wondered why the heck I still had it around after almost 10 years. Tossed.The difference between the two is a spacer in place of a reluctor, your motor will have a reluctor for the ds pump already installed, so either ds or db fluiddampr will work, if you get the one with a spacer ya just don't use it.....
I’m sure I would have found and alternate home for that spacer within a week or three.Came across my spacer a while ago and wondered why the heck I still had it around after almost 10 years. Tossed.
