fault code
Going to put this in the Allison OEM section. :)
P0700 only means that there are trans codes stored in the TCM. Have someone with a code reader capable of reading codes from the TCM scan and report what they are here.
A Tech II is about the only way I know of to read 700 codes. A conventional off the shelf scanner won't read those.
Your gonna need a TECH 2, EFILIVE, HPTUNERS, or I believe the new style SNAP-ON scanners can also read the TCM. Basic OBD2 scanners can not read it, and since you have an 06 it must be a CAN based scanner as well.
yeh thanks guys it makes sense i noticed right away that the tranny was not shifthing properly,i cleared the code and i have put about 100km since with no problems and tranny is shifthing ok at this point i will keep an eye on it but i wont worry about to much as its not the first time that this truck has done some funny elec. problems,actualy my both trucks have done some funny elct.problems thanks
I had a few P0700 codes a couple of years ago in brutal (-25 to -30 F) weather when I had some gelling problems and when I was running without a winter front cover. That's when I learned to be REAL easy on the throttle in severe cold. After that lesson I have never seen those codes again.
the weather here has been wierd lately we have had drastic changes where we see a +2celcius to -35 in 24hrs and like i said i had some codes that made no sense,last year i had a shift unable and the truck wouldn't move i shutt if off restarded and no problem, the check engine light come on,i drove the truck with no problems after a fiew restarts the light went out i put the reader on there was no codes stored,so i shrolled throught my settings in my dash and my hour meter reset itself to 0 i had a new truck so do not trust the hour meter when youre bying a used truck thanks mike
