Father's Day Gift Ideas
RockAutoLLC
Active Member
Vendor
Madison WI
Have you thought about what to get your "Do-It-Yourselfer" dad? Here are a few ideas from the RockAuto catalog!
Maintenance Parts: Get him the Oil and Filters he needs to change the oil in his daily driver, motorcycle or lawn mower. Throw in the Gear Oil he needs for the ATV as well. (Find the correct Engine Oil and Filter for his specific vehicle under “Engine." All Oil, Transmission Fluid, and Gear Oil can also be found listed under the “Tools & Universal Parts” tab.) Take advantage of the Mobil rebate and save up to $30 on Mobil 1 Engine Oil through September 30, 2021.
Accessories: Does the correct ball size for the boat, trailer, camper, etc. always seem to go missing? Gift him a multi-ball mount so he has the right size every time. Add extra vision when towing or hauling with an Outside Mirror Extender.
Supplies and Tools: The constant pressure hose clamps in modern cars can be challenging. Flexible Hose Clamp Pliers will make replacement easier. Help tackle the toughest grease, grime, stains and bacteria with Multi-Purpose Cleaner/Degreaser.
Let Dad Choose: Not sure which parts or tools your dad needs? A RockAuto Gift Certificate, available for any amount, will let your car enthusiast choose the parts or tools he needs.
MrMarty51
Miles City, Montana
I was going to order parts for the 1988 Buick Century. Got them all loaded into the cart, over $300.00 worth, went to check out and there was no where to insert the discount code for the order.
Decided to wait for a while, see if it’d come back. There was a box, where did You hear about us from. Was going to insert thetruckstop.us but that wasnt the discount code. 🤷‍♂️😩😹😹😹
RockAutoLLC
Active Member
Vendor
Madison WI
Hello,
Please enter the code in the ‘How Did You Hear About Us’ box to receive the discount. Please enter ONLY the discount code, no other words or numbers. All orders are placed online and the discount code must be entered before an order is submitted to receive the discount.
Thank You!
RockAuto.com
MrMarty51
Miles City, Montana
Parts is on duh way.
Complete ignition and fuel pump system.
I hope thats all this little pig is going to require for a very long time.
Only 145,000 miles and have done a fair job of keeping it reliable. But then it seems to always break somewhere unexpected.
This will be the third ignition module. That seems to be ratherly excessive for having only 145,000 miles on it.
Distributorless ignition. 🤷‍♂️
