Fan Clutch?
Ed HD
Formerly: Dad's 05 LLY
Chuck Town, Iowa
Hate to make all these threads, but it makes searching things in the future infinitely easier. RockAuto shows Hayden, Four Seasons and AC Delco for fan clutches, the Hayden being $75 and the AC Delco being $119. Is the AC Delco going to be $50 better? I don't want to replace it again for a while (doing it for PM as it is), and if it's worth it, then I'll do it.
C20ELEPHANT
Phoenix, Az
FWIW, I bought some "BOSH" glow plugs, they were in pretty BOSCH box, in the box was ACDelco glow plugs clearly etched "ADelco Made in Germany", so, nowadays with parts you never know what's in the box...
Ed HD
Chuck Town, Iowa
Got the Fan Clutch in. 2 notes: whatever jackass at GM decided to use those push-pins to hold the fan-shroud together needs to be shot, and no parts store carries the proper fan-clutch tool, so I had to make one with the holes in it work with a couple custom ground bolts, lol. The fan clutch was the easy part of the weekend though, lol.
NVW
Castor, AB.
Those push pins aren't that bad, once you figure out how the buggers work.
Ed HD
Chuck Town, Iowa
It's just the angle that you can't get at them at, and the fact that they were welded together after 10 years of heat and abuse. I ended up punching one of them out with a hammer and screwdriver. I bought new ones at the parts store, which I fully intend to have to destroy again in the future...
Olddieselguy
Salt Lake City, Utah
Here is a tip, when taking off threaded fan clutches use a air hammer and a long chisel bit. Knock the clutch in the direction to spin it off. Takes seconds to get them off.
  • Like
Reactions: NVW
THEFERMANATOR
FRANKENBURBAN
Staff member
Lead Moderator
ZEPHYRHILLS FL
Yyep, I've never used a wrench to take one off. The air hammer just works.
Ed HD
Chuck Town, Iowa
Actually it spun right off with the wrench I also borrowed from O'Reilly's, lol. Just holding the pulley was the hard part. I saw the Air Hammer tip elsewhere, but didn't need it.
tanman_2006
Just a farm kid...
Seiling, Oklahoma
On the lower clips the hold the upper and lower shrowd together I replace with zip ties. Otherwise the top ones aren't bad.
I built a spanner wrench thing too. Mine have never been too hard once I got the spanner wrench thing built.
Ed HD
Chuck Town, Iowa
I should have, but I needed a couple other things anyways, so I just made the rental work. It's our last vehicle with a mechanical fan, so I only need it for that, lol. Everything else is electric fans...
