Factory airbox: what am I missing?
GM Guy
Manual Trans. 2WD Enthusiast
NW Kansas and SC Idaho
Hey all,
I'm trying to get the OEM air filter setup put back together, and I wanted to check with anyone who has a known complete setup to check and see what I am missing.
I know I'm missing the 15834077.
I think I have the 15801087, but the one I can't really identify is the 15258717. Is it the scoop below the tray? Also, what retains the box to the tray? I'm aware of the two grommets (that I am missing) on the engine side, but what holds that bigger stub in the tray on the fender side?
IMG_20210121_094423189.jpgIMG_20210121_094529836.jpgIMG_20210121_094535292.jpgIMG_20210121_094542165.jpg
Im really not liking this 20 minute editing window...lol
Anyways, I think the 15801087 is the panel behind the headlight with the rib that is plainly seen in pic 2 and pic 4, and the one that the foam strip is resting against the rib in pic 1. Is this correct?
3 grommets hold it down. No bolts. I don't have the LBZ anymore but I pulled the airbox many times. The grommets do wear out.
