Chief915
915A Maint Tech
After doing a little more digging on my suburban, I have a couple questions. I got the numbers off the IP.... it's a DS4831-S5068 with a date of 7-10-1998 on it. I pulled the ECM and looked at the EPROM and it has the following numbers on it.
4244
BMSD
0152
There was also another EPROM laying in in the glove box with the following numbers on it.....
BMSD
1621
0150
A little more background info on the truck, in order to answer my questions.... 1994 K2500 Suburban, VIN F, 4L80E, 3.73 gears, 5068 IP with a green ID tag on the front.
Here are the questions
1) Which of these, if either one, is the "right" chip to use? The truck seems to run fine, but I am not sure what the story with the "extra" chip in the glove box is.... Is it the original, is it an extra, is the one in the ECM an update or upgraded chip, etc... I guess seeing the "extra" chip is what makes me wonder which one is the right one.
2) What is the difference between these two chips? I searched the forum and see that BMSD is one of a few different EPROMS that go with a 5068 pump, but what are the different numbers about between my two chips?
3) I have also read in various posts, through the search function, that the 5068 pump is a somewhat different DS4. I see that it takes a "special" eprom, but other than that.... is it any better or worse than the other model DS4's? Is this one more desirable than others, provided you have the correct EPROM for it?
Thanks in advance for your help.
4244
BMSD
0152
BMSD
1621
0150
