David Tune
Hello, I'm having issues with my egr and losing coolant internally and wanting to know if there's a way that you can just put the egr delete plates on without having to have a tuner?
Yes I'm trying to figure out if they even make a finger stick for my 2008 model and not having much luck so i don't think they do.If the LMM is like LBZ then you can get a "finger stick" to eliminate the code. Search with that term for that. I don't know what to tell you about the coolant leak in the EGR cooler at this point
