Big T
Need to buy a socket for the CV axle nut here in Montana, as the other made the trip to Fullerton earlier this year. Is it a 36mm?
I ran into at least 2 sizes.Need to buy a socket for the CV axle nut here in Montana, as the other made the trip to Fullerton earlier this year. Is it a 36mm?
I think mine were all the same other than some kits come with nuts and some of those nuts were smallerI have a 1-7/16ths socket which measures near to 37 MM. It is what I have been using on My 2000 K3500.
It does fit a tiny bit loose on the front axle nut.
I tried to get the caliper in on the wheel to get a more accurate measure but the length of the caliper and depth of the wheel would not allow that.
I have a shorter brass caliper that measured the nut at 36mm.
I dont know if the 2500 series would be a smaller size ?
