- Staff
- #1
What should the charging voltage be at idle if I measure it with a meter at the battery?
That feature is for gassers only, the diesel alternator should hold 13.5-13.8 HOT. When it is cold, it will go as high as 15.8 depending on temp. My AD244 will hit almost 16 volts if it's below 40 outside. Found this out the hard way as RV fridges are not happy with anything over 15 volts. Had to figure out what that annoying error message was it would flash out on a cold morning when I would start the truck up. I know mine will RARELY drop below 14.2 even with both airs on and the headlights at idle.Generally 13.5v. Some systems 2005+ kick the generator out at times to save fuel.
