docdray
Oompa Loompa
thought I would condense some info for boost fooler to help build this site.
WARNING this can increase boost, incorrect settings will result in severe engine damage. carefull of IAT, Use an egt and boost guage to verify.
using a 0-10k linear taper potentiometer,
MAP sensor on top of intake(black, square,w/3 wires)
1 right side potieniomenter to sensor -"b" wire-(center wire, usually green)
2 center of potieniomenter should be connected to the "b" wire-(center wire, usually green) going to wiring harness
3 the left side should be connected to ground, A (black wire), for voltage division.
suggested settings: 8500 ohms, turn up until ses lights then back off and tweak as you drive.
A fixed resistor can be substituted
anything I missed?
anything I missed?
