ripmf666
Registered user
If there is anything that anyone wants posted as of Gm spec's just ask.I can post anything that the dealer would use to do repairs to your car or truck.
I am curious as to what the difference in brakes are for 2500HD & 3500SRW (or 9,900 lb braking capacity) vs. 3500 DRW (or 12,000 lb braking capacity). Looking at the EPC the part number for the rear caliper piston is 18040104 for 2500HD/SRW and 18044321 for the 3500 DRW.
I guess all I am asking is if the difference in braking capacity is achieved with different diameter pistons?
would this be where I would ask for motor disassembly instructions?
such as head removal, crank removal and taking the pistons and rods off the crank and wristpins...if so...I'll be the first to ask for those...even the GM torque specs document if possible...
Thanks,
Pepp
PS Also assembly intructions...
Paul I will post the LB7 info first just need the HTML's turned on in this area its turned on in the TSB area and I posted the long DTC list.
Got it turned on for you Henry.
Thanks Jeff:cheers2: Need to talk with you one day about some grafics for my back window when you have time.
Do you have Access to the Factory Service Manuals in PDF Form that you could Post?
I am thinking of building a Fuel Pressure Tap for the Duramax engines. (Its like the one I make for the 6.5)
Anyway I would like to know the thead pitch and length of threads of the air bleed on the filter head. Also is the air bleed pre or post filtered fuel.
There are so many 6.6 forum sections that Im not sure where to post to get max exposure to the question.
Thank you.
Leroy
Thats a good piont, no LP no pressure.
So, dumb questions time.
1. Is the air bleed after the CP3?
2. Is the CP3 a lift pump or the IP? or is it just a high pressure pump?
3. What does CP3 mean?
Happy 4th
Henry,
can you help me with what these mean...I got these from EFI live scan tool on my wifes tahoe...
Diagnostic Trouble Codes
U1000 "Class 2 Data Link" H ($58) "Inflatable Restraint Sensing and Diagnostic Module (SDM)"
B3770 "Air Flow Control 6 (A/C) Feedback Circuit" H ($98) "HVAC Control Module"
B0408 "Temperature Control {single or 1} (main or front) Circuit" H ($98) "HVAC Control Module"
B0429 "Temperature Control 3 (rear) Circuit Range/Performance" H ($9A) "HVAC Control Module-Rear Auxiliary"
C0760 "Left Rear Low Tire Pressure Sensor" HC ($A1) "Front Passenger Door Module (FPDM)"
B1850 "(Left Front/Driver or generic) Seat Lumbar Horizontal Position Sensor Circuit" H ($A6) "Driver Seat Module (DSM)"
B3606 "Adjustable Foot Pedal Position Sensor Circuit" H ($A6) "Driver Seat Module (DSM)"
