icenutt
I have a 1994 k1500 6.5TD. My turbo has been working off and on for about 6 months. I have replaced vacuum lines, vacuum pump, wastegate solenoid. My turbo will work fine until I come to a stop sign. I take off and no turbo until I come to the next stop sign and then the turbo starts working again. I have just figured out that if I manually shift from OD into 3rd gear, the turbo starts working and works perfectly. As soon as I shift back into OD the turbo stops. Once in awhile the turbo will continue to work in OD until I come to a stop. When I take off the turbo stops working but I manually shift into 3rd gear and the turbo spins right up and works. Anyone have any ideas what is causing this? Thanks.
