CptTrog
200K and counting!
Hello, all. My Suburban's front end fuel system is in dire need of an overhaul. I was replacing the cooling system's thermostat and literally 'broke' the rubber fuel line connected to the small T-valve by simply moving it during the process! Quickly came to the realization that every rubber hose on top of the engine is dry-rotted beyond belief. Touch them and they break. I now have a pool of very expensive diesel under the intake and truck out of service.:mad2:
I've checked the site and found a number of schematics but nothing on the overall fuel line layout on top of the engine. [http://www.compnine.com/index.php?t...K&makecode=LG&grouptype=B&modelid=6934&uid=1]
It appears to be clear I'll need to remove the intake manifold to do the line replacements. Especially those two running to/from the fuel manager (filter) housing. There is just no easy way to get at them otherwise.
Any advice and or a pointer to a fuel line layout would be tremendously appreciated. I DO NOT want to get this wrong!
Thanks!
Thanks!
