6.2L 6.2 engine/trans
79jasper
Active Member
El Paso, TX
1982 "red block." With SM465 trans. Ran when pulled. When I got it was told it had around 80k miles on it. Doubt I put even 10k more.
Looking for around $750 obo. Can work out delivery up to 4 or so hours from 74070.
That muncie 4 speed isn’t a 4wd assembly with a xfer case is it? Those kick butt for off road with that low 1st gear.
Manual is better on a stick imo. I will let a couple folks round here know jic. Dang fair price for a runnin red block and a muncie 4. Should go quick.
20180929_131305.jpgI also have the axle from the same truck. 79 C30 with what I believe were in the neighborhood of 3.83 gears.20180929_131318.jpg
Update: make offer.
Can only turn quarter turn. Have pic of glowplugs.
Didn't have a lot of time to mess with it today.
Yup. Shot some penetrate into each hole.
Had to go back home to pull some 6.0 injectors though.. lol
Could even be in the trans. I might separate them, just to make things easier.
Scrapping engine.
Pulling fuel system, starter, clutch/flywheel, maybe some other stuff.
Speak up if you want/need something.
Have radiator, oil cooler lines, and all that as well.
And a hmmwv IP.
@79jasper FWIW and it's worth something:
1) Vac pump oil pump drive is worth $50 or so on eBay or as a primer tool.
2) Intake manifold may be worth $100 or so esp. if it's non-egr.
3) Glow plug controller may be worth something for restorations. Get all the sensors for the system.
4) T-stat crossover ~$100 or so. Maybe more if it's rare for 82's.
5) IP as a core is worth $25 on up to IP rebuilders.
6) AC belt drive brackets and pulleys have value to 6.2 military rig AC additions...
Other items a search on eBay can establish if it's worth bothering with.
Point of fact I have made back the $200 I paid for the scrap metal 6.2 just from some of the above parts. I still have to list some parts.
Thanks for some ideas.
It's a egr intake.
Is the early tstat crossover.
Gp controller was gutted when I got it.
I reckon I'll hold onto the accessory brackets for a bit.
I didn't think about the vacuum pump drive. Well, I did, just didn't know if it would be worth anything. Lol
I think I may have the IP's and injectors spoken for.
Still beautiful inside.
Injection stuff up for grabs. Make offer.
5 Bosch Germany injectors, 3 Robert Bosch USA.
