shadetree
bought a 95 w/sick 6.5td. (rod) lookin at a running 6.2 that was rebuilt about 4k ago. the ? do i need to worry about piston oil cooling w/ added heat from turbo. thanks
Heath GL4 prom, turbo-master, 4" turbo back, x-pipe, HO-Injectors, PMD-Isolator, aFe Stage 2 intake w/ S&B cone filter, twin 16" electric fans, TDC offset -1.94, one off propane injection system I helped design for the 6.5, Snow/Heath water methanol injection, ZEX diesel nitrous system, Comp-u-shift tranny controller, and eliminated the vacuum pump. I think that is about it. I am still working on trying to get 350 hp and 650 ft. lbs.
How do you like the Compushift controller ? What made you use that over the trucks ECM ?Heath GL4 prom, turbo-master, 4" turbo back, x-pipe, HO-Injectors, PMD-Isolator, aFe Stage 2 intake w/ S&B cone filter, twin 16" electric fans, TDC offset -1.94, one off propane injection system I helped design for the 6.5, Snow/Heath water methanol injection, ZEX diesel nitrous system, Comp-u-shift tranny controller, and eliminated the vacuum pump. I think that is about it. I am still working on trying to get 350 hp and 650 ft. lbs.
Dude, you are my hero. I want a dually with all your mods so i can put the Old man's 2003 ram in its place
Till he puts a Smarty Jr. on it and burns circles around you all day! :mad2::mad2::mad2: (I'm assuming this 03 Ram is a Cummins)
Personal message senthey guys need help fast , one of our tow trucks lost the bottom end and need to find out about a 6.2 or 6.5 short block .. i'd like to find a 6.2 with the use of a turbo. its a 97 k3500 ?? i know there r some out of state but i need something quick in minnesota or w isconsin.. bill 612 328 2169
If you are going to run a DS4 injection system I would run the 6.5 heads and injectors and use the fuel lines from the 6.5.
The engine will run the same as the 6.5.
Been done many times.
Good luck
I ruined a set of injector lines because I didn't know the 6.2 and 6.5 injector angle is different,lines must match the head. I'm running 6.2 heads with the turbo manifolds,the injectors are pretty close to the manifold on the turbo side.
