i got a 96 burb. i have the updated wiring for the electric actuator. the brown is ran to a key on 12v power source, then there's the other 2 wires that run to a 2 pin connector. if i can recall correctly, the 2 pin connector is suppose to have a mating connector. but i believe someone messed with this burb before i got it. The mating connector is missing and there is no 4wd relay on the firewall. I cant even find any sign that there was one. i spent 7 hrs strait, chasing wires and cant find what wire tells the actuator (ON) my question is, does anyone know what color wire and where it can be located at the firewall in order to run a new command wire from the push button switch to the front actuator in order for it to engage? the ground is easy i can ground that anywhere.
Thanks
Thanks
