Pat_Opsahl
I have a problem with my 4l80e transmission. It shifts very hard through all the gears and especially hard on the 1-2 shift.
It is a 1991 Suburban, 3/4 ton, 4X4 with 244k miles. Original engine, 350ci runs great. The original owner replaced the trans at 100k and I took ownership at 190k. I put in a rebuilt trans at 233k purchased from the dealer. It rarely got driven over the next 5 years. Last year the trans failed, stopped shifting out of 1st. I installed a used 4l80e from a 1996 hummer. It shifted hard from the get go. I put on several hundred miles, no change. The 1-2 shift is almost violent. I can kind of feather the throttle to help smooth the shifts. The engine revs high then the trans just goes fast and hard to the next gear.
I tried the Lucas trans additive. I drained 24oz out of the trans and put in the additive. OMG, it worked! It shifted perfectly normal. What is this miracle juice? Hold the celebrating, it went back to hard shifting after 150 miles of driving. Drove another 100 miles, still bad. I tried the additive again. Yeah, its shifting correctly again. This time I use the Suburban to tow a project car on my trailer, about 170 miles to its new location. Some good hard towing, worked perfectly. Then after disconnecting the trailer, back to hard shifting. What is going on? Any and all ideas are very welcome.
Thanks, Patrick in Northern Calif
