Cumminalong
Doghouse Diesel Performance
Below is how to do you the ball joints and wheel bearing / hub assembly on a 3rd Gen 2500 or 3500 SRW.
Word of caution.....this IS a labor intensive process. It can easily be done in the driveway, but plan on a weekend if you are by yourself.
Also, you MUST have a ball joint press for this job. Without it, you WILL NOT be able to remove the ball joints. I must say thanks to my buddy Tom for sending me (overnight) his ball joint press.
Please remember to use jack stands it you are under the truck. DO NOT rely solely on your hydraulic jack to support the vehicle.
Here is the removal portion. The installation portion will be in the next post.
Here is everything you are going to need for the job.....
