12ga diesel
Jack of all, Master of none
Here is some of the basic specs for the 3rd Gen Cummins engines. More or less the capacity of fluids and torque spces. If there are things that you think should be added to this, please feel free. I'm sure a guy like Rich (Cumminalong) will be able to add plenty. Just wanted to have this here where we could have one thread for everyone to go to when they have a question about specs.
2003- early 2007 5.9L Cummins Turbo Diesel
Oil capacity 3 gallons.
Oil pan plug torque 37 foot-pounds
FLEETGUARD LF16035 - STRATAPORE OIL FILTER ('03-'09) DODGE LISLE - FILTER WRENCH
FLEETGUARD FS19856 - 7 micron ULSD compatible o-ring.('03-'07, 5.9L) 29mm socket on the raised hex on the fuel filter housing.
Baldwin PF7977 Fuel Filter
FLEETGUARD AF26106 - AIR FILTER ('03-'07, 5.9L) DODGE
Valvoline Premium Blue
Shell Rotella T
Mobil Delvac 1300 Super
AMSOIL
Trans fluid capacity Service Fill (filter change and fluid fill)- 48RE (7.0 qts. ) ATF+4 Automatic Transmission Fluid
Overhaul or completely dry - 48RE 14-16L (17-18 qts.)
Transmission fluid pan bolts 125 in. lbs
Filter screws T25 35 inch pounds
MOPAR -MOP-52118789 REPLACEMENT TRANSMISSION FILTER ('98-'07 DODGE)
Part #04617210 Valve, Governor Pressure Solenoid ( TSB 21-009-07 )
Cooling System, Initial Fill 30.0 quarts. Warning only use HOAT and DI water mixture.
Gates Serpentine Belt K081264
Power steering fluid - ATF+4 Automatic Transmission Fluid
Transfer case 2.5 qts ATF+4 Automatic Transmission Fluid
Fill Plug.....15-25 ft-lbs
Drain Plug.....15-25 ft-lbs
Manual Transmission NV5600 6-SPD... 4.75 qt Synthetic Manual SynchromeshTransmission Fluid (MTF)
Fill Plug.....22 ft-lbs
Drain Plug.....30 ft-lbs
Manual Transmission G-56 6-SPD...6 qt. ATF+4 Automatic Transmission Fluid
TORQUE SPECIFICATIONS
Fill Plug 42 Ft. Lbs.
Drain Plug 42Ft. Lbs.
Front axle 9 1/4 AAM 74 oz = 2.31 qt 75W-90 or 75W-110 API GL-5 diff COVER BOLTS 30 ft-lb
Rear axle AAM 11.5 takes 122 oz. = 3.81 qt 75W-90 or 75W-110 API GL-5 diff COVER BOLTS 30 ft-lb
03-003-06 TSB for axle fluid fill level
rear pinion nut is a 36mm 12 point
front pinion nut is a 32mm
The only approved oil filters for Dodge's diesel engine are as follows:
Part # Manufactuer
5083285AA Mopar
LF16035 Fleetguard Stratapore
LF3894 Fleetguard Stratapore
LF3972 Fleetguard Cellulose
LF3552 Fleetguard Microglas
LF3959 Fleetguard Cellulose
3937695 Cummins Cellulose
FL896 MotorCraft Cellulose
L45335 Purolator Cellulose
PF1070 AC Delco Cellulose
Note: To maintain your warranty please be sure you use one of the above filters when servicing your truck.
Srw lug nut torque 135ft lbs
Drw lug nut torque 145 ft lbs
Shell Rotella T
AMSOIL
Part # Manufactuer
5083285AA Mopar
