- Staff
- #1
Here is a simple guide of common questions that are being asked around forums.
1.) Can I tune my LML with EFILive?
-A: NO, EFILive has said they will not support the LML for a number of technical reasons that have been implemented in the 2011 GM LML Computer.
2.) What is my wheel lug pattern?
-A: 8 x 180. This pattern is new for the 2011 GM HD trucks. No, previous generation wheels with not work, and like wise on the new wheels on previous trucks.
3 What is DEF? UREA?
-A: The new Duramax use new emissions technology in like with the DPF to keep a cleaner enviorment.
Wikipedia: http://en.wikipedia.org/wiki/Diesel_Exhaust_Fluid
4.) Can I remove the Diesel Exhaust Fluid system?
-A: There are aftermarket companies that allow you to reprogram your computer to allow the truck to run without the emission devices present on the truck.
However, it is likely to void your warranty as GM has issued several TSB's regarding aftermarket programmers. I advise to search and make your own judgement.
