What are you hearing from the other forums Jeff? I thought they put a heater on the DEF tanks. I know the new CL5 through 8 trucks have heaters.
Curiosity has me now. Is the heater running even when the truck is off? What happens if the system freezes, does the engine just not run right until it thaws? If it freezes solid will it crack the tank or lines?
No way that heater could run while the truck off. Batteries wouldn't last at all. One thing though, It makes you wonder why the DEF Tank heater isn't combined in with the cord on the block heater. Heating both while the truck is off.
If the heater for the DEF isn't somehow tied into the block heater cord, then GM (and any other manufacter for that matter) have a HUGE problem on their hands. I don't care how many re-flashes you do the truck, it ain't going to help. Are the Super Duty's and Rams having the same issues with the DEF?
I think only the 2011 & Newer C&C Dodge's Use DEF.
Just yesterday I talked to my dentist who's SIL is a Cummins field test engineer. They are working on SCR tests now, even though they swore they were gonna stick with only cooled EGR.
