1995 tahoe Stalls while driving
Bkno
Dayton
while driving the truck stalls sometimes and when it does i try to start it but it usually takes around 3-4 times before it turns over. I replaced the fuel pump, fuel filter, fuel lines, distributor cap and rotor buttons, plugs and wires, egr valve, egr circuit, IAC, and coolant temp sensor and I can’t figure out what’s going on. Any and all feedback will be very appreciated..
Thanks
Bkno
Dayton
The only codes it throws are for the knock sensor, EGR circuit, map sensor, coolant temp sensor, and the IAC all of which has been replaced. I haven’t checked the fuel pressure yet but when i try to restart the truck after it stalls you can smell the fuel. The truck is all stock with no mods
MrMarty51
Miles City, Montana
95, is that the first year of the vortec ?
I think there were some issues with fuel regulator and injector system on those first year vortec engines.
JMJNet
Recruit
Richardson, TX
I know we may have knowledgable gasser member but it looks like there is traffic in this thread.
My suggestion is to post at GMTRUCKCLUB forum.
Or search there, there are a lot more traffic for gasser over there.
I went there sometimes due to accessories similarity to the diesel truck like HVAC control, HVAC actuator, door lock actuator, etc.
