Having rear ac block kit installed - can anyone advise if an orifice tube should be installed on the condenser since it will be a front only ac?
Thanks very much
If you're just installing the plugs for the lines then no. The orifice will still be in the line going from the condenser to the evap. If you're replacing the Y line from the condenser with the single air one, then yes, you'll have to install an orifice either in the condenser or evap.
