1988 chevy cheyenne 3500 4wd pickup.
K.E.R.
Starter problem. Original went bad. Got new one at auto parts store. Worked for just a couple months. Now it won't start. Looking for an original starter or some advice of what to do.
Make sure battery cables are good w/ clean connection at all ends.
Once you are sure the starter is toast- follow the above advice. Powermaster 9052. Little more price, a lot better quality. You wont believe how much easier your engine starts.
And make sure the little front bracket is on regardless of which starter you run. Without it the block ear can break off.
@ak diesel driver also posted up the faster cranking RPM for the Powermaster Starter.
Blast from the past...
