tanman_2006
Just a farm kid...
Truck in question: My cousins 05 LLY/allison crew cab dually 4x4 w/ bale spike flat bed, KNN cold air (he wont change to dry flow), 5in exhaust, edge w/ juice, 187K miles. My uncle bought it from the Dealer with 30K on it and the dealership used it to haul their cars. My cousin got the truck 2 years ago.
The truck had been leaving a steady fog of smoke while cruising since edge was installed at 20K miles (reason the dealer sold it). My uncle figured it was normal since it had good power when you leaned into the happy pedal.
Edge programming update cured it 75% of the time. MPG went from 11 highway to 16-17 highway
Now the truck has low power and wont boost past ~8PSI (setting doesnt have any effect and neither does load) unless you floor it then it will hit +22psi. When the boost sticks at 8psi it smokes pretty bad even cruising.
After you floor the truck runs normal with little to no smoke and boost builds freely.
Is the turbo gummed up? Is there a sensor that could cause these symptoms?
