GM Guy
Manual Trans. 2WD Enthusiast
Hey all,
We have been offered a 01 GMC K2500HD 8.1L Allison Reg. Cab 8ft flatbed truck.
Pretty straight unit, and he is only asking 1500.
The previous owner sank 4 grand into the transmission getting it rebuilt.
Current owner ran it for a while, and then one day he got in it and it would not move. He did not remember if the circle around the indicator flashed or not.
He did say that occasionally the speedometer would die and come back, abs, check engine light, etc. Basically all that was working reliably was the tach, fuel, oil pressure, coolant, and volt meter.
It has been off road alot, was a cowboy bale bed truck first, then the trans rebuild, then the current owner had a flatbed on it and used it around the farm.
SO, I wanted to ask you guys what the worst case scenario on this truck would be? could there have been a rebuilder or installer error the last time around, and there could be major issues, or is it sounding like a speed sensor and a NSBU would be all that it would need to fix it?
Any input appreciated,
Thanks!
Thanks!
