you guys using weight distributing hitches?
Discussion in 'General Recreation' started by MattZ71, May 19, 2008.
  1. MattZ71
    MattZ71 Tennessee Diesel's Mod
    355
    0
    May 16, 2008
    KY/TN line
    you guys using weight distributing hitches, what link you yall use in the chains?
  2. 06HD2500LLY
    06HD2500LLY D.I.L.L.I.G.A.F
    I use a combo type, sway and weight with the bars on each side. If I can remeber right on the type I think your talking about, the third link is the one your after. Dont quote me on that. I used to have one of those awhile back.
  3. DMitch
    DMitch Recruit
    48
    0
    May 7, 2008
    Vermont
    What link you use will depend on how you want to put load on or take load off the tow vehicle. They are what will determine how weight gets distibuted.
  4. MGlickLBZ
    MGlickLBZ Agent Quack Smacker
    234
    0
    May 5, 2008
    South Central, WI
    It was always the third link. If you can, get an Equalizer, they are much easier to deal with.
  5. MattZ71
    355
    0
    May 16, 2008
    KY/TN line
    Equalizer? ive never hard of them, where can i look at one at?
  6. alli_gator
    alli_gator Recruit
    101
    0
    May 9, 2008
    Las Vegas
    Me too, that is where mine tows the best.
  7. HDpullingpower
    HDpullingpower Hellion
    208
    0
    May 4, 2008
    Chestertown MD
    I use the Reese dual friction sway control and WD...mine is on the 5th link..I think.
  8. Ozzie
    Ozzie Snow looming...run!! Moderator
    2,866
    20
    Feb 10, 2008
    Apple Valley, Minnesota
    Mine has the solid bars and brackets...no chains.
    I can tell you though if you adjust it too hard to try and push that front end down of your truck, it will ride like crap and beat you senseless.
    Let the back of the truck take some weight, your back will thank you for it.
  9. copter
    copter Toy Hauler
    73
    0
    May 4, 2008
    Nor*Cal
    4th or 5th link depending on the amount fuel on the back of the TH (56 gal).
  10. Rttoys
    Rttoys Recruit
    348
    0
    May 7, 2008
    Houston, TX
    http://www.equalizerhitch.com/
    Much much much better than the chain and friction sway combo. I used that for about one year and then switched to the Equal-i-zer, night and day difference.:sifone: The truck/trailer now pulls as one unit, no sway at all. Only hook up 2 bars and go. No need to remove the sway control when making tight manuvers, either. It's a very nice system.
  11. MattZ71
    355
    0
    May 16, 2008
    KY/TN line
    thanks brother, ill check it out!
  12. Ozzie
    2,866
    20
    Feb 10, 2008
    I use the Equal-i-zer too...that name is actually the name of the product, although that type of hitch is commonly called that because they've been around so long and established a standard. Back in the 60's, it used to be marketed by driving the old front wheel drive Toronado into shows with the rear wheels removed towing a trailer. A pretty effective marketing tool,eh?
    Short of spending a couple grand on a Hensley-Arrow, it's about the best you can do.
  13. RayMich
    RayMich Active Member
    4,717
    5
    May 9, 2008
    Mid Michigan
    Anybody using one of these?
    Hensley Arrow
    [​IMG]
    [​IMG]
    [​IMG]
    Many people swear by these, but they sure are expensive.​
    They claim that, "It is physically impossible for a travel trailer to sway, fishtail, or jackknife when outfitted with the Hensley Arrow®," and they have some impressive videos showing how it works.
  14. MattZ71
    355
    0
    May 16, 2008
    KY/TN line
    How much do them hitches go for?
  15. RayMich
    4,717
    5
    May 9, 2008
    Mid Michigan
    Very expensive ($3,115 to $3,165 depending on what size distribution bars you get). They do have a 60-Day Money-Back Guarantee & Lifetime Warranty.
    Hensley Arrow Pricing
    http://www.hensleymfg.com/pricing.htm
    Occasionally they run specials on them. People who own them claim that it's the best money they have spent.
    You can get a lot more information if you click on the links in my post above.
  16. jb23
    jb23 Recruit
    59
    0
    May 4, 2008
    Illinois
    Ray is that your mini van pulling the camper , nice looking rig. That's a lot hitch for pulling a camper, is it easy to hook up
  17. Rttoys
    Rttoys Recruit
    348
    0
    May 7, 2008
    Houston, TX
    Hensley Arrow is in the neighborhood of $3000, worth every penny so I heard..........but that's a hard coin to swallow.
  18. RayMich
    4,717
    5
    May 9, 2008
    Mid Michigan
    Sorry, No.
    I got that picture from the Hensley website. :)
    According to Hensley, the hitch is fairly easy to hook up. And according to postings I read on RVnet, everybody that has one says that they will never again tow without one. Supposedly, it drives like a straight truck. No sway whatsoever. The hitch is set up with a set of linkages that allows it to turn, if the tow vehicle initiates the turns, but if the trailer tries to turn it, it acts like it's locked up and won't let the trailer sway. It's quite ingenious.
    If you click on the links I posted above you will go to their website. They have a lot of information about their hitch.
    You can order on line their FREE video DVD and learn more about their hitch. It includes a demo video showing how it works. Its' quite an impressive piece of equipment.
    They also sell a state-of-the-art brake controller that people claim to be the best.
  19. jb23
    jb23 Recruit
    59
    0
    May 4, 2008
    Illinois
    That Ray to much for me
  20. MattZ71
    355
    0
    May 16, 2008
    KY/TN line
    in thinking about getting the Hensley-Arrow and doing away with the chains!
Share This Page
