What tranny came stock
Discussion in 'GM Manual Transmissions' started by Twisted Steel Performance, May 19, 2018.
  1. Twisted Steel Performance
    Twisted Steel Performance Formerly: sctrailrider Vendor
    1,653
    1,265
    Jan 15, 2012
    Pauline, SC
    My 93 K3500, someone swapped from auto to NV4500 at some point, with the 93 being all manual what tranny would have come stock??
    Was considering a Allison swap but sense the truck still has the wiring from the auto it makes more sense to have a strong 4l80 built maybe...
  2. MrMarty51
    MrMarty51 Well-Known Member
    1,286
    1,165
    Aug 1, 2017
    Miles City, Montana
    4L60E would have been the original in a 1500 series.
    93 and 94 used the same trans but 95 was a different aminal.
  3. ak diesel driver
    ak diesel driver 6.5 driver
    12,847
    2,871
    Feb 7, 2009
    alaska
    If it was a diesel it would have had the 4l80
    MrMarty51 likes this.
  4. Twisted Steel Performance
    1,653
    1,265
    Jan 15, 2012
    Pauline, SC
    OK, so what is the difference between 4l80 & 4l80E, I'm thinking no wires were cut during the swap because I see in places the connectors are just empty now.
    If I were to look for a built auto tranny would it need to be a 4l80 or 4l80E , I'm guessing the "E" is electronic of some sort?
  5. 79jasper
    79jasper Active Member
    341
    226
    Nov 10, 2013
    El Paso, TX
    Technically there's no such thing as a 4L80. As they are all Electronic.
    Even if it doesn't have the E at the end, it's still a electronic 4L80.
    Sent from my SM-G892A using Tapatalk
  6. Twisted Steel Performance
    1,653
    1,265
    Jan 15, 2012
    Pauline, SC
    Yep, I've been reading after I posted this, guess I should have done that first..
    MrMarty51 and 79jasper like this.
  7. SnowDrift
    SnowDrift Radical Right Wing Extremist
    If you would like a '95 4L80E to swap in, I know a guy that would like to take the NV4500 and components off your hands.
    smokymtn65 and MrMarty51 like this.
  8. WarWagon
    WarWagon Well it hits on 7 of 8...
    8,249
    2,691
    Nov 15, 2009
    AZ
    IMO a 4L80E is strong enough. Put the improvements in like 5 pinion OD gearsets. Get a triple disc converter stalled for your build - just for the better lockup clutch. The converter can overcome the big RPM drops some gears have. Change trans oil every 25k miles.
    Converter lockup clutch gives me 50k OEM, and the 3rd gear overrun clutch is quickly toast with no improvement available. It's only used for compresion braking.
  9. Twisted Steel Performance
    1,653
    1,265
    Jan 15, 2012
    Pauline, SC
    I will keep you in mind, this isn't going to happen right now tho..
  10. SnowDrift
    I'm good with that. As time permits, I'm not going anywhere and neither is my truck. If we get down your way for a vacation in the next year or two, we'll try to drop by.
  11. THEFERMANATOR
    9,007
    2,370
    May 9, 2008
    ZEPHYRHILLS FL
    If you're using stock electronics, you're stuck using a 91-93 EARLY 4l80e transmission. You can add in the output reluctor since Sonnax is now making replacement's, but theres not much you can do to get around needing the 91-93 valve body. Your only option would be custom programming or a stand alone controller if you can't find a 91-93 4l80e.
  12. ak diesel driver
    12,847
    2,871
    Feb 7, 2009
    alaska
    didn't the vans use a TCM with mechanical injection later than 93?
  13. THEFERMANATOR
    9,007
    2,370
    May 9, 2008
    ZEPHYRHILLS FL
    Yes they did, but it never came with 4x4. Ask those who have done the db2 swap with the GM tcm what happens in 4low.
  14. deejaaa
    deejaaa Diesel Beginner
    1,647
    451
    Sep 19, 2008
    Texas
    mine came with the 4L80E. i was having trouble getting a signal so i installed the TCI EZ-TCU. works great. keep the stock TPS to same a few dollars. put in a floor shifter w/ reverse lockout from TCI also.
    MrMarty51 and Will L. like this.
  15. THEFERMANATOR
    9,007
    2,370
    May 9, 2008
    ZEPHYRHILLS FL
    If it was mine, I would run the late 99 or newer 4l80e, and a stand alone controller. The early 4l80e's got alot of improvements through the years. By mid year 99 GM had the bugs worked out and most of the weak points weeded out.
Share This Page
