We are LIVE
Discussion in 'GM 6.5 Diesel Engines' started by Twisted Steel Performance, Apr 13, 2018.
  1. Twisted Steel Performance
    Twisted Steel Performance Formerly: sctrailrider Vendor
    1,631
    1,204
    Jan 15, 2012
    Pauline, SC
    Hink, Husker6.5, KrisML and 4 others like this.
  2. EWC
    EWC Active Member
    223
    74
    Jun 14, 2008
    Ok , so devils advocate . Why should I buy your heads ? As was posted , numbers would help . I think that if you put up some numbers from a stock head and yours , that would help . Also maybe have some stages for a build . Heads give you this much , coatings add to that , etc . With an overall plan of how much power is possible , that might get people interested in mods . And I wouldn't just limit this to just power improvements . If the coatings , valve unshrouding and other improvements help with cooling or more boost , touch on that .
  3. Twisted Steel Performance
    1,631
    1,204
    Jan 15, 2012
    Pauline, SC
    The numbers will be posted when I'm done with them.
    And how many different combos would a person need to build?
    Their are plans being worked on for many dyno test with various combos, heads & coatings are just part of it.. it's coming later this year.
    I already know the interest level is low on this site, but it isn't low in other places by no means..
    Be patient, when I have more news I will let it out..
    Husker6.5, KrisML and n8in8or like this.
  4. ak diesel driver
    ak diesel driver 6.5 driver
    12,754
    2,757
    Feb 7, 2009
    alaska
  5. WarWagon
    WarWagon Well it hits on 7 of 8...
    8,156
    2,528
    Nov 15, 2009
    AZ
    I believe you have more interest here than you give yourself credit for. It may just take years to save up for things...
    "And how many different combos would a person need to build?" I don't think that's the question being asked.
    Power costs money and somewhere between a complete engine swap to something proven to produce power and building a 6.5 is the gray area you are in. In this context I think the question is "All or nothing?" or "What expensive steps do what and what can I leave off for the budget?" Sometimes the savings of a $200 step on $2000 worth of heads has to be pointed out as not smart. After all if I don't have a budget then why not drop in a 1000 HP hopped up 5.9 Cummins and call it a day.
    Good example is using too small NA precups where money spent on good 6.5 turbo heads makes a difference. (Budget and didn't know better at the time.)
    So maybe "power only" mods, cool running mods... Or if they all play well together maybe just numbers on the kitchen sink build is all you need.
  6. ak diesel driver
    12,754
    2,757
    Feb 7, 2009
    alaska
    I think one of the other factors that will come into play is fuel or lack thereof. Best heads in the world will only give you power that you can fuel it.
    WarWagon likes this.
  7. Twisted Steel Performance
    1,631
    1,204
    Jan 15, 2012
    Pauline, SC
    Your right.. The new pump I have has the highest cc numbers I've seen in person, other folks have made claims but I haven't seen the data sheets from them, I have with this one... and if it's not enough I have a new 350 plunger also yet to be worked on...
  8. ak diesel driver
    12,754
    2,757
    Feb 7, 2009
    alaska
  9. Twisted Steel Performance
    1,631
    1,204
    Jan 15, 2012
    Pauline, SC
    @ak diesel driver ... forgive me but I'm keeping that quite for the moment BUT I will post the data sheet when the engine dyno time is here..
  10. Big T
    Big T Well-Known Member
    3,498
    977
    Sep 25, 2009
    Fullerton, CA
    Stormy Daniels is interested in the 350 plunger.
    KrisML, WarWagon and 79jasper like this.
  11. Twisted Steel Performance
    1,631
    1,204
    Jan 15, 2012
    Pauline, SC
    I guess I need to get out more... who ?? :confused:
  12. Twisted Steel Performance
    1,631
    1,204
    Jan 15, 2012
    Pauline, SC
    Google is your friend.... never mind LOL...
  13. Will L.
    Will L. Well-Known Member
    7,396
    5,990
    Jan 25, 2013
    Boulder City Nv
    Well, the easier an engine can flow in and out, the more efficient.
    Like, 3” exhaust pipe is ok size, but going to 4 or larger lets if flow so much easier that the same turbo can function better with the same amount of fuel. Plus getting rid of the heat easier.
    It is really hard to have a head flow too well, especially a diesel.
    Husker6.5, KrisML and WarWagon like this.
  14. Husker6.5
    Husker6.5 135' diagonal 16:9HD, 25KW sound!
    1,691
    1,108
    Feb 10, 2011
    Lincoln, NE
    Does it flow too well when the breeze blows the flame out, @Will L. ?
    Will L. likes this.
  15. quadstar87
    quadstar87 Active Member
    108
    91
    Sep 11, 2012
    PA
    Awww c'mon ; ) I posted mine. Doesn't mean crap till it runs! reliably
    Husker6.5 likes this.
Share This Page
