Uneven rear end, how to fix?
Discussion in 'Steering, Suspension and Wheels' started by konstan, Aug 26, 2011.
  1. konstan
    konstan Diesel junkie
    85
    3
    Aug 2, 2010
    Omaha, NE
    Got a 95 Sierra 2500 4wd with a 6.5 td motor. If you look at the truck straight from the back, the driver side sits lower.
    I heard tell that it's the fuel tank location that causes this after so many years... So, how can I correct this?
  2. New springs in the rear and crank the bars up front.
    Or the poor mans/redneck way is to shim the sagging side the amount it's sagging.
    IE: 2 inch sag equals two inch block on the offending side. Cost less than twenty bucks.
    Do it right a few hundred.
  3. konstan
    85
    3
    Aug 2, 2010
    Omaha, NE
    Lol just spent a few $$$ on pmd relocation w/new pmd; what's the downside to the redneck method?
  4. btfarm
    btfarm 300,000 Worth Staff Member Moderator
    15,957
    1,232
    May 12, 2008
    Sandwich, Illinois
    Measure it at all 4 corners. Then I would try cranking the driver's side T-Bar 1 turn 1st (make sure you are up on stands), let it down, bounce it and then measure again to see what difference. Work from there.
  5. I wouldn't carry a heavy load in the bed or tow with a high tongue weight, and it's just a band-aid but won't really do any harm if you don't overload it.
    You could also put helper springs/load leveler {adjustable} on the springs and adjust them to even out the load and be able to haul/tow.
  6. bk95td
    bk95td 6.5 nut job/addict
    2,548
    9
    Nov 26, 2008
    Broken leaf springs.Check the sides of the leafs for cracks right above the axle. There is no real "band aid". The broken leaf or leaves need to be replaced. Messing with the torsion bars will only throw it out of alignment further. Figure on a new centering bolt and new u-bolts.
  7. great white
    great white Well-Known Member
  8. konstan
    85
    3
    Aug 2, 2010
    Omaha, NE
    I went out and measured. Axle to frame, ground to frame, all are the same on the left and on the right.
    Then I measured "top of the bed to ground" and sure enough, it's 1" off.
    So, the bed is seated unevenly, with rear pass. corner too low by 1". Can this be corrected?
  9. Ed HD
    Ed HD Formerly: Dad's 05 LLY
    3,082
    251
    Jul 6, 2008
    Lakeville, Minnesota
    Sounds like your bed mounts are bad. I'd check them for rust and see if one is rotted away, and if not I'd replace the bushings. That should fix it.
  10. konstan
    85
    3
    Aug 2, 2010
    Omaha, NE
    Ok thanks, I will look into the bed mounts/bushings being bad.
  11. bk95td
    2,548
    9
    Nov 26, 2008
    There is no bushings between the box and frame. Only the cab and core support have bushings. The box is solid to the frame with 8 bolts.
    A broken main leaf spring behind center of the axle will allow the frame to sag that much. Measuring height at the axle will still be good.
  12. konstan
    85
    3
    Aug 2, 2010
    Omaha, NE
    Axle to frame is the same on both sides.
    Axle to ground is the same because it's 1/2 of the tire height. (lol)
  13. bk95td
    2,548
    9
    Nov 26, 2008
    Correct. What I'm saying is that if the main leaf[the one that bolts to the frame] is broken at the axle ,that it still will support the frame in front of the axle but not behind it.
    Maybe I'm totally wrong. Maybe the truck was crashed in the rear and the frame is bent. Adjust the bumper to match the box and it won't be as noticeable.
Share This Page
