  1. Philbilly2
    Philbilly2 Just a speck on the wall
    I thought I would do a write-up on getting an extra 2 inches out of your truck without doing anything crazy.
    All you need is this:
    Factory GM Part Numbers:
    4- #11588351 (1-Ton U-Bolts)
    2- #15712451 (2 inch blocks)
    2- #15592573 (Green Keys)
    I chose to replace my shocks because mine were long overdue:
    Bilstein Part Numbers:
    2- F4-BE5-E381-TO (Cognito Motorsports GM K2500 Fronts)
    2- F4-BE5-B514-HO (GM K1500 6" Lifted Rear Zinc Shocks)
    Either way, if you have green keys, your shocks are what is limiting your front end right now. Loose the factory shocks or put the shock mount extenders and you will get alot more out of them.
    Here is the difference:
  2. Philbilly2
    So, the before:
    [​IMG]
    And the after:
    [​IMG]
  3. Philbilly2
    Here is how easy it is
    You need the torsion key tool:
    [​IMG]
    First jack up the front end so there is no weight on the keys
    Use the torsion key tool to take the load off the keys
    Back out your torsion key bolt
    Slide the bolt retainer out through the side
    Then unload the keys
    Once you get the keys unloaded, just slide your trosion bars foward (they will slide out of keys)
    Put the new keys in and revese this process
      File size:
      57.4 KB
      375
      File size:
      71.4 KB
      70
      File size:
      74.3 KB
      64
      File size:
      63.2 KB
      398
      File size:
      66.9 KB
      56
  4. Philbilly2
    For the rear end:
    [​IMG]
    Support the truck to the frame so the the suspension can droop
    Put a floor jack under the pumkin
    [​IMG]
    Unbolt your u-bolts
    Let the rear axle down
    [​IMG]
    [​IMG]
    Put the blocks in and your 1-ton u-bolts on
      File size:
      61.2 KB
      365
      File size:
      68.3 KB
      365
      File size:
      66.8 KB
      367
      File size:
      67.4 KB
      27
  5. jcool
    jcool #78 A(ACLU) FNG
    1,097
    0
    May 4, 2008
    Richlands, NC
    about how much did that cost you to do? I have already turned my tbars up 1.5 inches so I would be just doing the blocks in the rear so really I guess thats the cost I need
  6. Philbilly2
    Overall project took me about 2 hours on a creeper in my garage:
    Very happy with the way truck looks now
    Just always remember to get truck alligned after all is said and done.
    Overall cost:
    Bilstein shocks: $400 w/shipping
    Ubolts: $23.46 x 4= $93.84
    Green Keys: $34.59 x 2= $69.18
    Blocks: $27.22 x 2= $54.44
    $217.46 w/o shocks
    $617.46 w/ shocks
  7. jcool
    1,097
    0
    May 4, 2008
    Richlands, NC
    you mean I can't do my redneck alignment?:wtf:
  8. Philbilly2
    that's what I got right now.
    Thats the one where you need a 6-pack right:
    [​IMG]
    The more you have, the srtighter it looks :yikes:
      File size:
      60.4 KB
      373
  9. jcool
    1,097
    0
    May 4, 2008
    Richlands, NC
    you are sooo spot on my friend....
  10. got-h2o
    got-h2o HillBilly Pimp
    313
    0
    May 10, 2008
    NW Indiana
    Looks great. Howz it ride??
  11. Mad Maxx
    Mad Maxx See, what had happened was... Staff Member Moderator
    5,995
    118
    May 3, 2008
    Long Island, NY
    Damn, that's a pretty good difference, more than I though before seeing the bigger pics.
    Nice work!
  12. Philbilly2
    I never realized how much the factory shocks suck.
  13. Dura-Ration
    Dura-Ration No Obuma
    815
    1
    May 13, 2008
    Escatawpa,Ms.
    Man, That Looks Sharp!
    :hurray:
  14. MattZ71
    MattZ71 Tennessee Diesel's Mod
    355
    0
    May 16, 2008
    KY/TN line
    I LOVE IT...thanks for the write up!
  15. Will
    Will Boobies make me happy
    Nice write up Phil. Truck looks good.
  16. Philbilly2
    Thanks guys, It is a huge change, should have done it long ago
  17. 12ga diesel
    12ga diesel Jack of all, Master of none
    1,766
    31
    May 4, 2008
    McHenry,IL
    Nice work and a nice write up Phil. I also found it to be a bigger difference then I thought after seeing your pics. So the Bilstiens are the way to go huh?
  18. HemisAreSlow
    HemisAreSlow FREE!!!
    1,078
    2
    May 3, 2008
    will this still work if you have a 3500 srw? or will I have to buy even bigger u bolts?
  19. Philbilly2
    You will have to have even bigger u-bolts, I don't know if maybe ones from a 4500 or 5500 might work?
  20. Philbilly2
    Sorry dave, yeah, the bilsteins are awsome damn thing rides like a caddy now, my old shocks were bad.
    I love um, but they are expensive!!!!!!!!!!
Share This Page
