Turbo ID
Discussion in '6.5 Performance' started by cub124, Mar 8, 2012.
  1. cub124
    cub124 Half Moon Detroit #1
    195
    0
    Mar 25, 2011
    stormstown PA
    Hey guys just picked up two turbos, one off of a CAT 3116 and another off a mack truck. The CAT turbo looks like it was built by CAT and has a split t3 or t4 flange, anyhow the one Im having trouble finding info on is the Airesearch turbo off of the mack. It has a split flange which i think is a T6.
    The Airesearch
    Inducer:65mm
    Exducer: 93.8mm
    serial No. SFR0405 R
    It also has M11 on the intake housing and "11" on the body
    The intake is 3.5"
    exhaust is 4"
  2. turbonator
    turbonator Member
    758
    10
    Nov 15, 2010
    Lac Superieur, Quebec
    The Air Research, is actually a re-badged Garrett, and the turbo from the Cat, will be a re-badge also. Without seeing it, our guess would be a Schwitzer (4LE303). Hope it helps you in info searching. Compounds.....??? This sizing for secondaries would require copious amounts of fuel.
  3. cub124
    195
    0
    Mar 25, 2011
    stormstown PA
    Ha no compounds yet I just picked them up cheap and hope to resell. Yeah i knew it was a Garrett Im just having trouble finding another one like it online to find a value for it. The Garrett is non waste gated
    The CAT turbo is internal waste gate and needs rebuilt, here are some pictures
  4. turbonator
    turbonator Member
    758
    10
    Nov 15, 2010
    i am not a mind reader... or able to devine from simple pictures what it is.... find the build plate on it and post it up....
  5. cub124
    195
    0
    Mar 25, 2011
    stormstown PA
    will do, I know it was off of a 1977 mack inline with an inline 6
    Ill post the other number on the turbo tag, this is the one i had posted first: serial No. SFR0405 R
    If you mean the build plate on the engine thats about an hour away, should have written the specs down.
  6. turbonator
    turbonator Member
    758
    10
    Nov 15, 2010
    so did you sell the cat turbo?
  7. cub124
    195
    0
    Mar 25, 2011
    stormstown PA
    yes it has been sold, sorry
  8. cub124
    195
    0
    Mar 25, 2011
    stormstown PA
    Just cleaned a little on the plate and I found the label P/N so the part number is 631GC5106X I was unable to find much from google with this number.
Share This Page
