Tricks for leveling campers (side to side)
Discussion in 'General Recreation' started by MTdmax2003, May 9, 2008.
  1. MTdmax2003
    MTdmax2003 Recruit
    41
    0
    May 8, 2008
    Montana
    Who has good tricks or ideas for leveling your campers side to side? I have no problem with front to back. We end up camping on uneven areas with my 5er and I haven't come up with good ways to level it side to side. I can get it level side to side but then I have trouble getting the camper hooked back up to the truck because the king pin is at such an angle.
  2. SaguaroKid
    SaguaroKid A(ACLU) Mojo Man
    369
    0
    May 8, 2008
    Eyeowa
    A side pivoting 5th wheel plate helps?
  3. MTdmax2003
    MTdmax2003 Recruit
    41
    0
    May 8, 2008
    Montana
    Unfortunately, my 5th wheel plate doesn't pivot side to side, only front to back. Any idea how much a side pivoting 5th wheel plate would cost?
  4. SaguaroKid
    369
    0
    May 8, 2008
    Eyeowa
    I'm not sure but you may have to get the whole hitch?
  5. HDpullingpower
    HDpullingpower Hellion
    208
    0
    May 4, 2008
    Chestertown MD
    Have you tried bottle jacks and stands..then you can lower back to original height to hook up.:idea:
  6. truckie481
    truckie481 Dagum
    682
    0
    May 4, 2008
    Cleveland, NY
    I carry pre cut 2" X 12" lumber that is the length of the distance from my front wheel to the rear wheel (so both wheels fit on it) and then I pull in to the site determine what side needs to be raised, back up far enough to place the boards down and then pull up on to them. With a bit of time you can be pretty acurate.
    I have a reese 16k with slider that pivots, I paid less than $700 for it new.
  7. SaguaroKid
    369
    0
    May 8, 2008
    Eyeowa
    Independent front jacks would be nice.
  8. WYOMAX
    WYOMAX New Member
    34
    0
    May 10, 2008
    WYOMING
    Dig a hole for your tires on the high side.
  9. skiandplay101
    skiandplay101 Refugee
    19
    0
    May 10, 2008
    Tucson, AZ
    X2 on the 2x12 for the tires and my front jacks have the adjustable slides with many a holes for when you are hitching or unhitching. Just look at the ground before you try to unhitch. Rear jacks also help alot.
  10. Ozzie
    Ozzie Snow looming...run!! Moderator
    2,866
    30
    Feb 10, 2008
    Apple Valley, Minnesota
    I use the 2x's also...with a level on the front of the trailer so I can see how much lumber is needed. Staggering the boards so one wheel is on one, and the other on two splits the difference too.
  11. DunesRunner08
    DunesRunner08 Banned
    1,417
    0
    May 7, 2008
    Phoenix, AZ
    I have dual guages and switches for my airbags...I can level it side to side and front to back that way
  12. MTdmax2003
    MTdmax2003 Recruit
    41
    0
    May 8, 2008
    Montana
    How many 2X's are you guys talking about? stacking them 2 or 3 high?
    Thanks for the good ideas. I wish I had the air bags. That sounds like that would be the easiest.
  13. blizzardplowman
    blizzardplowman Crowd Control Staff Member Moderator
    655
    0
    May 3, 2008
    SE WI
    I carry 3 2x in the truck bed, use what ever I need when we pull in the site, works great. My hitch pivots side to side also.
  14. HDGMC
    HDGMC New Member
    32
    0
    May 12, 2008
    Take the same number of 2x's that level the trailer and place a 2nd set on the same side under the rear wheel of the truck. You may want to drill some small holes and drive some spikes into the ground to keep the driven wheel from pushing the board(s).
    You could also carry a straight 2x6x8' and place it on edge at the point that you want the rear axle of the trailer to be after you have parked. Use a level on the board to determine how many blocks will be needed to provide a level platform. Set those blocks and back the trailer in. Just before the trailer climbs the blocks, set the same number (or similar according to terrain) in back of the rear axle of the truck. Back the trailer and truck onto the blocks.
    (If the road is crowned and you want to use the leveling board, simply place a block under each end of the leveling board, then figure out how far out of level the pad is and use the appropriate number to level the trailer.)
  15. MTdmax2003
    MTdmax2003 Recruit
    41
    0
    May 8, 2008
    Montana
    Thanks for the great ideas! I'm itching to go camping now! :driving: Unfortunately too busy next weekend. Too many kids activities going on.
  16. truckie481
    truckie481 Dagum
    682
    0
    May 4, 2008
    Cleveland, NY
    I carry two 2x12 that just fit in to my longest compartment and a bunch of 12x12 pieces for the down riggers.
  17. MGlickLBZ
    MGlickLBZ Agent Quack Smacker
    234
    0
    May 5, 2008
    South Central, WI
  18. richard cheese
    richard cheese the MAIN muff hugga
    345
    0
    May 7, 2008
    i only camp in the sand, and the sand makes it easy to shovel from underneath the tires of the high side...for you...you might need to crank the jacks for more than just "stability", if you know what i mean
  19. MGlickLBZ
    234
    0
    May 5, 2008
    South Central, WI
    You mean when the spousal unit pukes all over the bed?:smileydan:
  20. havns3
    havns3 friction lover
    132
    0
    May 8, 2008
    northeast missouri
Share This Page
