"The Tick"
Discussion in '01-04 LB7' started by schulte, May 4, 2008.
  1. schulte
    schulte ACCELLERANT!!!
    420
    0
    May 4, 2008
    Southern CT
    Most LB7 owners know what I'm talking about.... THAT ticking noise. GM seems to think it's no big deal.
    One question for LB7er's though; ever notice it getting worse before a serious bang?
  2. SfcJones
    SfcJones A(ACLU) SGT. SLAUGHTER
    3,508
    25
    May 3, 2008
    South Ga.
    I hope not, some have suggest that after 220k miles I may have a fix by adjusting the valve lash, no one has told me for sure and for 500 bucks I want to be sure
  3. whitetrash21
    whitetrash21 Put on the damn helmet day........
    788
    0
    Apr 29, 2008
    Vegas
    bang... not yet. damn things been tickin since i got it. i keep my right foot planted most of the time so i cant hear it.
  4. Gruber
    Gruber Tin Can Rider
    504
    0
    May 4, 2008
    1000 Oaks, California
    I guess I'm lucky. My LB7 doesn't tick yet. I only have 45,000 mile on mine.
  5. jcool
    jcool #78 A(ACLU) FNG
    1,097
    0
    May 4, 2008
    Richlands, NC
    no tick here either. almost 116k too.
  6. Sparky8370
    Sparky8370 Do chickens have large talons
    1,703
    0
    May 3, 2008
    New Hampshire
    I'm assuming you guys are talking about something other than the normal tick that they all have. I've got a slight one after doing my head gaskets. I accidently swapped the racker assemblies and bridges around. So I will have to adjust them sometime.
  7. Hammer 4
    Hammer 4 Have Hammer..Will Travel
    241
    0
    May 5, 2008
    San Pedro, So Cali
    No tick here...but my cluster gauges stopped working today..:D
    Not to worry, I tugged on the wiring harness that goes to the fusebox on the side of the dash...and Wa La..gauges worked fine. Must be a bad conection in there..:nonod:
  8. CrewCabMax
    CrewCabMax Double XL
    5
    0
    May 7, 2008
    Springfield O.H.I.O
    ticking could be injectors. I had a ticking before i put the new set in, and now its gone. You can use EFI or a scan tool and do an injector kill test to see if your ticking is cause from the injectors.
    Joe
  9. Clark20ry
    Clark20ry Agent #58 OB-DII A(ALCU)
    1,679
    0
    May 5, 2008
    Surprise AZ
    The only ticking I get is after an oil change... it usually goes away after a couple hundred miles....
  10. Bagofdimes
    Bagofdimes Recruit
    24
    0
    May 8, 2008
    I had the "tick" a long time ago...It went away at about 30K and I haven't heard it since. I have about 130K on it now. It went away before I installed my edge and straight pipe too. Strange. Engine still runs great though, on original injectors too!
  11. 66FLH
    66FLH "The Big Kahuna"
    943
    1
    May 7, 2008
    New Mexico
    Mine sounds like a rod knock under light load.Pisses me off!
  12. kachurak
    kachurak New Member
    227
    0
    May 3, 2008
    Watertown, NY
    Thats good news on the injectors. Mine made it to about 180k
  13. SaguaroKid
    SaguaroKid A(ACLU) Mojo Man
    369
    0
    May 8, 2008
    Eyeowa
    My 02 had the tick my 03 doesn't.
  14. ROCKYMTN
    ROCKYMTN Pain in the arse
    228
    0
    May 5, 2008
    Mile High + 1000'
    My 03 had the tick till the Odometer read about 10,000. The Lilly has none!
  15. TwoTone
    TwoTone Im here for the Cake!
    115
    0
    May 9, 2008
    Wyo
  16. Clark20ry
    1,679
    0
    May 5, 2008
    Surprise AZ
    I was thinking the same thing when I read the thread title.... ):h
  17. fbh31118
    fbh31118 Cadet
    49
    0
    May 9, 2008
    Augusta, Michian
    Is there a procedure for adjusting the valve lash. Isnt this what causes the tick?:confused5:
  18. Foreman00081
    Foreman00081 New Member
    66
    0
    May 12, 2008
    Rochester, NY
    whats this tick sound like and when do you hear it? i do have an odd tick sound that i can hear when im sitting in the truck and its idleing but its only about every 10 seconds or so and almost seems like its coming from the door panel or drivers side mirror, ive never been able to track it down and its not very loud.
  19. Heartbeat Hauler
    Heartbeat Hauler A(ACLU) Agent Yoda
    2,079
    1
    May 4, 2008
    Morgantown, WV
    My tick went away after the fourth oil change, 20k miles...give'er take a few.
    JP
  20. tomrex
    tomrex Professional Idiot
    Typewriter tick here! Only after an oil change. I don't pay any attention to it. It normally goes away in a few hundred miles. When I switched to Delvac, it went away faster.
Share This Page
