stripped Rear Break Bleeder Help.
Discussion in 'GM 6.5 Diesel Engines' started by pgguru, May 10, 2008.
  1. pgguru
    pgguru Recruit
    I replaced the Break lines to the back of my truck and I found that the bleeder on the drivers side was spun round by the previous owner. I tried to get it with a set of needle nose Vise grips but I cant get a hold of it.
    Any one have any Idea besides dropping half of the axle? It is a tight fit between the 13' drums and the leaf springs.
  2. 94K30
    94K30 Diesel nut
    230
    0
    May 9, 2008
    manchester CT
    you can remove the wheel cylinder and get a better grip on it...
  3. Acesneights1
    Acesneights1 New Member
    10,018
    10
    May 5, 2008
    Northeast CT
    Take the wheel off and remove the wheel cyliner. Once you get it in a vise you can probably get it loose. Of course once you've gone that far why not just replace it?
  4. pgguru
    pgguru Recruit
    I replace the Line to the rear Flex Line. I know if I try to remove the Rear Cylinder the lines on axle will be stuck to the tubes and break and they are a B!tch to make. And if I have the cylinders out I will just put new one in. I think there is a option for 1/16 inch bigger.
  5. Blueburby1
    Blueburby1 New Member
    110
    0
    May 10, 2008
    Toronto Area, ON, CA
    torches, and regular style visegrips....give it a shot....but be careful heating up the wheel cylinder...do NOT go cherry or your gonna get some mighty nasty surprises
  6. NVW
    NVW Well-Known Member
    8,458
    820
    May 5, 2008
    Castor, AB.
    "Flame Thrower" comes to mind:holyshirt: Leo
  7. Blueburby1
    110
    0
    May 10, 2008
    less of a flame thrower, more of broken lines, popped cylinders, and burnt faces
  8. teroma25
    teroma25 Recruit
    X2..you don't need a lot of heat, just a little and work it back and forth real slow till it threads out.
  9. Truckie174
    Truckie174 Hmm....Whats this button do?
    42
    0
    May 11, 2008
    Pendleton, Indiana
    I've got a nasty little scar as a reminder of a popped line on my arm. Rubber doesn't cool off as nearly as fast as you want it to.
    You would think that burning through a shirt first would cool it down. :mad5: But it don't!
  10. beaglehauler
    beaglehauler Recruit
    26
    0
    May 8, 2008
    heat it a little and try an easy out,worked for me a few times
Share This Page
