6.5L Stand alone controller TCM
Discussion in 'For Sale' started by Sand, Oct 8, 2016.
  1. Sand
    Sand Active Member
    137
    155
    Mar 27, 2016
    Canada
    GM standalone transmission controller for 6.5 Diesel. Suits a DS4 to DB2 conversion. I recommend Bobbys guide for the DB2 conversion as a read if you are considering this. I bought it to put a 4L80E in a Humvee but ended up with a H1 that already had a 4spd. Now its surplus.
    Price 100 dollars obo
    Shipping - actual cost.
    Item is in Canada - postal code VOR 1S0
    Sandy
    MrMarty51 likes this.
  2. Will L.
    Will L. Well-Known Member
    7,024
    5,191
    Jan 25, 2013
    Boulder City Nv
    I wonder if it is the same as 95 and older hummers. I dont really need a spare, but hmm.
  3. THEFERMANATOR
    8,850
    2,085
    May 9, 2008
    ZEPHYRHILLS FL
    The actual controller might be the same, but I wager the prom is different. GM stopped putting in a tone wheel into the output shaft of 4x4 4l80e's after 93, so the tcm has to know when its in 4 low to recalculate the output speed since it used the vss instead. This is why everybody that used these had problems in 4 low was it wasn't setup to recalculate for low range.
    MrMarty51, Will L. and FellowTraveler like this.
  4. Sand
    Sand Active Member
    137
    155
    Mar 27, 2016
    Canada
    But a good inexpensive unit for 2wd conversions.
    MrMarty51 and FellowTraveler like this.
  5. LowRam
    LowRam Member
    35
    74
    Feb 1, 2018
    Michigan
    Still have it? Been quite awhile since you posted it, but, what the heck, don't know unless you ask
  6. Sand
    Sand Active Member
    137
    155
    Mar 27, 2016
    Canada
    Still here, lol. Pm me.
    Sandy
  7. LowRam
    LowRam Member
    35
    74
    Feb 1, 2018
    Michigan
    Ha! Great. Umm, how does the PM work on this forum?
  8. Will L.
    7,024
    5,191
    Jan 25, 2013
    Boulder City Nv
    I click on the name of the person by the meme-
    Where his says “Sand active member”. Then click on “start a conversation” then you type a header in top box and below is the conversation. Then below that click box that says start conversation.
    When someone responds back or Starts one with you at the top right of your page you have an “inbox”. Click that to open and read/ respond to a PM (aka conversation). Cool thing about this one is you can have a group conversation with a few people.
    Also if you fill out your signature line with your rig info it will help in the future with questions.
    LowRam, MrMarty51 and Jaryd like this.
Share This Page
