squeak when turning while towing
Discussion in 'General Recreation' started by blizzardplowman, May 13, 2008.
  1. blizzardplowman
    blizzardplowman Crowd Control Staff Member Moderator
    655
    0
    May 3, 2008
    SE WI
    Guys, I got a squeak that shows up only on turns when pulling my toy hauler. Sounds like a metal on metal type rub, notice it more while turning a hard right , the left is not as often or as loud. I've lubed the hitch, checked the trailer springs (lippert triple 6k axles), can't find crap. any ideas? :mad2:
  2. truckie481
    truckie481 Dagum
    682
    0
    May 4, 2008
    Cleveland, NY
    I would check wheel bearings.
  3. blizzardplowman
    655
    0
    May 3, 2008
    SE WI
    Not that kid of squeak, its only when turning a corner and it will match a rough road bounce, like a metal rubing metal sound..
  4. 66FLH
    66FLH "The Big Kahuna"
    943
    0
    May 7, 2008
    New Mexico
    Leaf springs are all I can think of.Lend it to me for the Memorial Day weekend and I'll try to duplicate it!):h
  5. campingworld550hauler
    campingworld550hauler Recruit
    19
    0
    May 5, 2008
    central NY
    to the best of your knoledge what direction is it coming from? rear of truck, front,, hitch area(bed) trailer??? more info and we will try to get it for ya'!!
  6. blizzardplowman
    655
    0
    May 3, 2008
    SE WI
    Long haul just to get close to you :crazy: I have thought about the springs also.... Just not sure what to lube. FWIW trailer has about 30k on it, we have put 3k on it this year already.. Dang fuel prices:sick:
  7. blizzardplowman
    655
    0
    May 3, 2008
    SE WI
    Behind me is all I can tell, worst when turning right. Straight down the road or changing lanes will not make the noise. Drives me nuts....Not that I have far to go ):h
  8. 66FLH
    943
    0
    May 7, 2008
    New Mexico
    If it's a fiver,check all of your mounting points on the hitch.
  9. blizzardplowman
    655
    0
    May 3, 2008
    SE WI
    I did , but will dbl check them, I was wondering if it was hidden under the trim, might need to have a look :(
  10. DunesRunner08
    DunesRunner08 Banned
    1,417
    0
    May 7, 2008
    Phoenix, AZ
    Your leaf springs are first thing that come to mind, but I also know that the way my chains are attached they cause a squeak all the time
  11. truckie481
    truckie481 Dagum
    682
    0
    May 4, 2008
    Cleveland, NY
    Did you figure your squeak out yet?
  12. cwq21
    cwq21 Member
    720
    0
    May 15, 2008
    Brusly, La.
    Without hearing it, and just a guess, its' probably the springs, bolts & shackles.
    The reason I say that is when you turn a 2 or 3 axle trailer and while looking at the tires and wheels, you can see a lot of torque on the suspension.
    I just upgraded mine to a wet bolt (greasable) kit with bronze bushings. All that was in there when I removed the old bolts and dropped the springs and hangers down was plastic bushings that had almost wore through.
  13. blizzardplowman
    655
    0
    May 3, 2008
    SE WI
    Interresting, Who did you get the "upgrade" from?
  14. cwq21
    cwq21 Member
    720
    0
    May 15, 2008
    Brusly, La.
    I have the Mor Ryde suspension system and I had to order it through them because of the special plate that goes in between the springs. If you do a search, Dexter makes most of the wet bolt kits.
    After getting the upgraded/modified plate, I could have made mine work with some metal lathe work and mig welding.
    Kind of pricey. Dealing with Mor Ride was cheaper:
    http://www.trailair.com/products/equaflex/pricing.php
    For the Dexter suspension:
    http://www.dexteraxle.com/inc/sdetail/18099
    My kit was $170 from directly from Mor Ryde. They sent me the prints for the different models of suspensions that they produce and I called them back and made the order.
    FWIW, before ordering, measure the center to center distance between the springs in the middle and let them know that measurment.
    I hope this helps explain things a little more.
    Charlie
  15. SFC Cobb
    SFC Cobb Jesus Freak
    1,910
    0
    May 15, 2008
    Hurst, TX
    Is the trailer a 5th wheel or a tongue pull? Did you lube the hitch plate or use a nylon dri lube disk?
    If it is a tonque pull, are you using a sway control? If so then it is probably the sway control. Do not grease it or it won't work. Back off the friction.
  16. blizzardplowman
    655
    0
    May 3, 2008
    SE WI
    41' fifth wheel toy hauler, lub disc.... I am leaning to the shackel bolts. hope to pull one apart this weekend.
Share This Page
