Some Random GM Part Numbers
Discussion in 'GM Duramax Engines' started by coldLBZ, May 11, 2008.
  1. coldLBZ
    coldLBZ Recruit
    21
    0
    May 9, 2008
    Alberta, Canada
    These are just some part numbers I have written down, I'm unsure if they are all still current.
    29539579 Allison spin on
    29537965 Allison shallow sump filter
    88917036 AC Delco PF2232 oil filter
    89060534 Fuel filter TP1298B
    15918221 LBZ air filter
    Hope this helps.
  2. HDpullingpower
    HDpullingpower Hellion
    208
    0
    May 4, 2008
    Chestertown MD
  3. Pepperidge
    Pepperidge Member Advocate Staff Member Lead Moderator
    12,367
    364
    Feb 10, 2008
    Slidell, La
    I don't have em' but I bet the idler pulley tensioner for all models would be great...
  4. WhitetailAddict
    WhitetailAddict Recruit
    260
    0
    May 9, 2008
    Central Pennsylvania
    Here is the GM part # for the hub assembly, just replaced mine. Updated GM #15946732
  5. coldLBZ
    coldLBZ Recruit
    21
    0
    May 9, 2008
    Alberta, Canada
    97188684 Exhaust manifold to cylinder head gasket
    97188685 Exhaust manifold to up pipe gasket
  6. bud9899
    bud9899 Recruit
    92
    1
    May 7, 2008
    SE, GA
    Baldwin Filter #'s:
    02 LB7
    Oil: B1441
    Air: PA4113 (I trimmed the sharp corners off)
    Fuel: BF7827 (Looking inside it seemed identical to the AC I took off)
    I went with the Allison spin on from the Alli dealer and 2 gals of transynd.
    Don't forget to keep your magnet on the top of the filter!
  7. BigDogYJ
    BigDogYJ Recruit
    348
    2
    May 8, 2008
    Kommifornia
    Fuel Filter
    Wix #33910 / Napa #3910
    These numbers are from fleetfilter.com. Last I checked the fuel filter was around $23 each.
Share This Page
