So i blocked it
Discussion in '06-07 LLY/LBZ' started by BigBlueBurban, May 9, 2008.
  1. BigBlueBurban
    BigBlueBurban Umm no...WAIT...yes
    98
    0
    May 7, 2008
    Grand Rapids, Michigan
    But forgot to finger it! :blush2:
    Installed the blocker plate today. Drove the truck about 25 miles to Lowell and shut it off for about 10 minutes. Start her back up, presto CEL. P0401, Insufficient EGR Flow. Durrrrr :cuss:
    I did however notice an immediate increase in throttle response and according to the DIC (i know i know, just using as a reference), I've gained a tenth of mile per gallon.
  2. stacks04
    stacks04 McLovin
    3,579
    0
    May 9, 2008
    terryville ct
    yeah the response if very nice. that egr is worth less imo. they just released a bulletin the other day to just replace th egr motor on the p/u trucks now. no more valves and assm. wonder how many will be back in a month or 2 after that.
  3. Cheyenne19
    Cheyenne19 Special agent C19 A(ACLU)
    540
    0
    May 4, 2008
    The Delta
    I guess I should get off my tail and block mine.
  4. BudTX
    BudTX Edjumacated Redneck
    That blocker plate is a cheap and easy modification that really makes a difference.
  5. stacks04
    stacks04 McLovin
    3,579
    0
    May 9, 2008
    terryville ct
    yeah block it. then you can get efi live to turn the light off:D
  6. BigBlueBurban
    98
    0
    May 7, 2008
    That's what I'm planning on doing eventually. However, I need a bit of help guys. I'm trying to install my MBRP front pipe that I got from Kyle at XDP (thank you Kyle!) and I can't get the damn converter past the crossmembers. Do I have to lower the trans crossmember to get this beast out?
  7. Unit453
    Unit453 Cruises comfortably at 140... Staff Member Administrator
    7,124
    4
    Feb 10, 2008
    Bradenton, FL
    I never blocked my 04 LLY. I havent blocked this truck yet either. I've heard of too many people losing mileage by doing so.
  8. richard cheese
    richard cheese the MAIN muff hugga
    345
    0
    May 7, 2008
    a few years ago that wouldnt have made a difference to me...but when im paying more per week for diesel in my truck than what i pay in electricity to my house for a month....every little thing counts
  9. Grendahl
    Grendahl Does not play well with others
    217
    8
    May 1, 2008
    Syracuse, NY
    Nope. At least not if it is the same as my '04. You just need to remove the hanger bracket that comes off the side of the transmission. You should then be able to twist the converter pipe around and take it out toward the front of the truck. Its a tight fit, but it should go.
  10. Cheyenne19
    540
    0
    May 4, 2008
    The Delta
    I've done it on an 05 and it is a tight fit, but you won't have to move any crossmembers.
  11. BigBlueBurban
    98
    0
    May 7, 2008
    Finally got it out. Took me forever to realize that hanger bracket unbolted off the transmission.
    And WOW, what a difference. B!itch is loud as hell. :devil:
    One more question. Is it possible to bolt up the front pipe a little off center? I think I may have but I'm not sure :blush2:. The clamp looks like it's tighter and in a bit of a different position on one side than it is on the other :wtf:
  12. Grendahl
    217
    8
    May 1, 2008
    Syracuse, NY
    That front clamp can be a bit tough. I didn't notice a big change in sound when I changed mine out so maybe you didn't get the front clamp sealed up just right. You should be able to feel around the area with the truck running to see if you can feel exhaust gasses blowing out. I swap mine out with the converter each year for inspections, so I've had some practice with it.
  13. BigBlueBurban
    98
    0
    May 7, 2008
    Definitely will have to check that because something isn't sounding right...
  14. BKDespain
    BKDespain Recruit
    184
    1
    May 8, 2008
    Utah
    PPE's tuner has tuning in it that turns off the egr cel. I had a superchip in and unplugged the egr and the cel was on all the time, then I swithed to PPE and and blocked the egr. Now CEL free.
  15. BigBlueBurban
    98
    0
    May 7, 2008
    I was thinking about getting a PPE programmer to get rid of the light, but I'm holding out for EFI Live.
Share This Page
