RPO code UF3- high idle
Discussion in '07.5 - 2010 LMM' started by blizzardplowman, May 4, 2008.
  1. blizzardplowman
    blizzardplowman Crowd Control Staff Member Moderator
    655
    0
    May 3, 2008
    SE WI
    It actually is a $200 option on the 08's - RPO code UF3., if this option was not included on your GMT900 truck you can add it , most dealers will charge a fee to do so.
    Ask the dealer to call tecline and request that they add UF3 high idle to the BCM software. they will need your full vin# and they may charge you a bit for it, also you may want to call them about it and have them get the calibrations changed beforehand as it can take up to a day or so, but it can be done.
  2. HemisAreSlow
    HemisAreSlow FREE!!!
    1,078
    1
    May 3, 2008
    is there a way to engage high idle without the temp being below 32? High idle would be nice to have if your running a large power inverter or have your truck at idle for a long time....like sleeping in it at night
  3. Did you actually get the dealer to do this for you? My neighbor was told by GM TAC that they had no plans to allow the dealers to do it. He is really interested in getting done for his truck if this is true.
    Thanks,
    Mike
  4. WhtThndr3
    WhtThndr3 Yeah, I'm that guy
    Yes, I finally figured it out..had to read the manuel:lol:, but truck in park, parking break set, cruise on, hit set...it will jump up. I did it this weekend and it was 75f outside.
  5. blizzardplowman
    655
    0
    May 3, 2008
    SE WI
    My Dealer is working on it now, I will post when I get it done.
  6. Thanks,
    I'm sure he will be interested in the details - he's been chasing getting it done for months and has about given up.
  7. RayMich
    RayMich Active Member
    4,724
    12
    May 9, 2008
    Mid Michigan
    I heard that same thing from someone who wanted to replace their 245/75R-16 tires with the optional 265/70R-17 on a 2008 LMM and wanted the computer reprogrammed. Evidently the dealer told him that GM TAC said, if you didn't order your truck with that option, then you are SOL. They will no longer give the code to the dealer to upgrade a truck that didn't have the option from the factory, even if you give them the correct VIN.
    Typical arrogant BS.
Share This Page
